Author Topic: PCL: CosmeticCorrection module  (Read 69655 times)
Offline vicent_peris
    • http://www.astrofoto.es/
Re: PCL: CosmeticCorrection module
« Reply #60 on: 2012 April 11 15:48:36 »
Just one suggestion for this module. For me it would have much more sense to select the bad pixels by sigmas of the noise distribution than a threshold level. Could this be possible?
Vicent.
Offline NKV
« Reply #61 on: 2012 April 11 23:43:39 »
Yes, it's possible. However, the sigma for the selected level is shown in the GUI ;)
You can use Level or QTY slider to set the sigma.
But, if you really need separate NumericEdit/slider for sigma, I will add it.
« Reply #62 on: 2012 April 12 00:15:21 »
Ouch! Sorry, I was somewhat sleepy last night! :-P
Anyway, I think it's more logical to have the sigma slider. I would prefer to see the gray level that corresponds to the desired sigma and not the sigma that corresponds to the desired gray level.
Thanks!
Vicent.
Offline NKV
« Reply #63 on: 2012 April 12 08:28:59 »
v1.2.0.6 +Slider for select the bad pixels by sigmas of the noise distribution in MasterDark :)
Offline sleshin
« Reply #64 on: 2012 April 12 10:15:25 »
NKV,
Your amazing. Thanks for all the great contributions you make to PI.
From a grateful user.
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline Harry page
« Reply #65 on: 2012 April 12 10:36:09 »
Having a bad day  :o  How do we replace the existing module  :-*
Harry
Harry Page
Offline NKV
« Reply #66 on: 2012 April 12 11:33:52 »
Just close PixInsight and replace the file.
Offline Harry page
« Reply #67 on: 2012 April 12 11:40:37 »
Cheers  8)
Good job you have a brain
Harry
Harry Page
Offline NKV
« Reply #68 on: 2012 April 12 18:18:29 »
Offline tsaban
« Reply #69 on: 2012 April 24 00:01:20 »
I just wanted to test this script after watching Harry's latest video about the Calibration Script. Even though I downloaded the script as described here and have the latest version of PI installed (1.7.6.703) the mask looks much different than in Harry's video. I attach a screenshot below.
Btw. I have an x64 Windows machine. Any idea what can be wrong?
Thanks!
Clear skies!
Tahir Saban
Offline NKV
« Reply #70 on: 2012 April 24 00:21:10 »
This is topic about CosmeticCorrection Module.
CosmeticCorrection Script is other story.
Module is more powerful version of the script.
Offline tsaban
« Reply #71 on: 2012 April 24 10:11:53 »
Thanks! I was mistaken by the icon which is normally used for scripts and was already wondering how such complex things could be done in a script :)
Clear skies!
Tahir Saban
Offline jeffweiss9
« Reply #72 on: 2012 April 24 13:43:15 »
Can someone say how to install the module, as it is different from the script?
Thanks.
-Jeff
Offline NKV
« Reply #73 on: 2012 April 24 18:19:02 »
The module distributed via standard update system.
Are you have update trouble?: Solution for "There are no updates currently available for your PixInsight"
Offline cs_pixinsight
« Reply #74 on: 2012 May 03 14:53:20 »
Nikolay, since the BatchProprocessing script was updated to output multi-images fits (dark, low and high rejection maps all in one file), the CosmeticCorrection module fails to open the master dark being generated by the script.
Would it be possible to update this module to properly read these new master images?
BTW, thanks for the great module.
Craig
