Author Topic: PCL: CosmeticCorrection module  (Read 69737 times)
Re: PCL: CosmeticCorrection module
« Reply #30 on: 2012 February 21 09:53:14 »
Nikolay,
Is this module ready for release? I can build it for all platforms as soon as you say it's ready.
Offline NKV
« Reply #31 on: 2012 February 21 10:11:34 »
Nikolay,
Juan, I don't like how look interface, especially in RTP section. If there are any idea how to improve it, please push me.
Also I think, need some time for catch bugs, if there are...
Otherwise, You will need build bug updates very soon.
Best regards,
Nikolay.
PS What about publication update for Blink?
« Reply #32 on: 2012 February 21 15:34:52 »
Nikolay,
how about publishing modules that are not yet perfect but which you would like to see tested by a larger community in the Update-Development repository, see http://pixinsight.com/forum/index.php?topic=3335.0 . For the GradientMergeMosaic process, this helped to find a lot of nasty issues fairly quickly.
Offline NKV
« Reply #33 on: 2012 February 22 22:47:24 »
v 1.1.0. buid 4
Temporary, BigFix version: In previous release there are potential bugs in not important features( Invert with STF and not *.fit file support ) . I don't have solution for those bugs. So I temporary disabled those features.
Georg, good idea. I will ask Juan after solving that problem http://pixinsight.com/forum/index.php?topic=3881.0
I say "after" because actually, current version is 32bit limited, so I must rewrite InstanceEngine parts of the module.
Best regards,
Nikolay.
Offline mmirot
« Reply #34 on: 2012 March 01 06:31:36 »
I had trouble with the 64 bit version. I could not get RT preview to start.
Max
Offline mmirot
« Reply #35 on: 2012 March 01 19:02:23 »
Got it Ok now
Max
Offline NKV
« Reply #36 on: 2012 March 08 12:02:48 »
v 1.2.0 build 1
+ List of Defects: Entering manually Row/Column defects and Save/Load text file.
When RTP starting, depend on selected correction methods, RTP engine prepare up to 5 defective map images.(ColdMasterDarkMap, HotMasterDarkMap, AutoColdMap, AutoHotMap, MapFromDefectiveList).
Plus 3 MorphologicalTransformation Light images ( Average 3x3, Median 3x3, BackGroundMedian 7x7 ). In CFA case size of MorphologicalTransformation Structure have double size.
For example: AutoDetectHot/Cold require all type of MT Light images plus require ImageStatistics. AutoDetect is very slow method, but as you can see on PrintScreen provide result similar to fastest DefectiveList method. See Screen.
So, if you try start RTP on full size MainView image a lot of preparation required.
If you like fast RTP start, just start it on small preview window.
Offline troypiggo
« Reply #37 on: 2012 March 08 13:32:29 »
Not clear reading through this if there's been an OSX 64 bit version compiled?
On a side note, I have downloaded the js version.  Wondering what the differences/benefits of PCL version are?  If there's a js and PCL version available, same features, is one better than the other?
Offline NKV
« Reply #38 on: 2012 March 08 21:46:33 »
OSX is not available.
To Juan: Can you compile it for other OS? And publish it via Update-Development repository? Please.
JS vs PCL:  :D
1) JS running in modal mode, so you don't have access to results. It's like use a hammer with closed eyes. Where and how the hammer will strike is unknown.
2) If JS GUI is open, you can't use other useful tools. No STF, no RTP. Impossible to get or check data from workspace.
For example, if you need to enter some coordinate to GUI: In PCL you can click on the pixel and immediate see result in RTP or in the image directly. In JS you should write the coordinate on paper, run JS, then enter manually, run JS( close the GUI ) and check result via blinking or undo/redo.
So, JS is not convenient, but JS can run on any OS without additional code manipulation.
Best regards,
Nikolay.
ADD: v 1.2.0 build 2
+ Generate Defective List by mouse click on image. How to use: Select defect type(Row/Col) and click in image to readout coordinates.
But note, there are bug in PixInsight Core 01.07.05.0779, so don't use that readout features in RTP window.
« Last Edit: 2012 March 09 01:00:34 by NKV »
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #39 on: 2012 March 15 03:09:09 »
again, great tool. Worked like a charm on my test image.
Juan, is it possible to have it soon in all platform (OSX 64) maybe in "dev" update ?
Offline troypiggo
« Reply #40 on: 2012 March 15 03:36:31 »
If someone can let me know the tools to compile, I'll give it a go.
Offline NKV
« Reply #41 on: 2012 March 19 01:36:52 »
Source code in first post.
I can compile it for Linux and Win.
« Reply #42 on: 2012 March 19 01:43:53 »
I'll try to compile it for all platforms ASAP. Can we release it as an update?
Offline NKV
« Reply #43 on: 2012 March 19 01:50:21 »
Yes, this module is ready for release.
Best regards,
Nikolay.
« Reply #44 on: 2012 March 19 01:55:14 »
Great! :) Release it via update or update-devel ?
