Author Topic: Mac OS X 64 bit updater no-install loop  (Read 21822 times)
Offline JMc
« on: 2011 August 28 15:31:27 »
Mac OS X.6.6
Pixinsight V1.07.00.0697 Starbuck (x86_64)
On startup, Pixinsight tells me I have ten updates available. I enable the updates, close the application, and then I see a dialog that asks if I want to install updates (the restart application box is checked). I click yes, and nothing happens.
When I restart the program, this loop repeats. Why won't the updates install on exit? I am the sole user on this machine and have admin privileges.
Re: Mac OS X 64 bit updater no-install loop
« Reply #1 on: 2011 August 31 13:49:07 »
I haven't seen anything similar to this before. As far as I can tell, the update system works perfectly on Mac OS X.
Anybody can confirm this problem? Anybody can figure out the cause of this?
Offline JMc
« Reply #2 on: 2011 September 08 13:48:07 »
Rebooted the system and the same loop repeats:
On starting Pixinsight I have a dialog that announces updates, click the box and they download:
Packages downloaded:
  10 successful
   0 failed
Downloaded packages are now scheduled for installation.
The updates will be installed when you exit this instance of the PixInsight Core application.
Should you need to cancel the scheduled update, you can do so by selecting Resources > Update > Unschedule Update Installation.
I click APPLY and exit PixInsight (Dialog box):
Update packages have been scheduled for installation. Do you want to install the updates now?  (restart Pixinsight box is checked)
I click yes ... nothing happens. PI does not restart automatically, the updates are not applied. Should I reinstall PI? Is there a library or pref file that needs deletion?
Can I get a link to re-download the latest version of PI and skip this FUBAR update process?
« Reply #3 on: 2011 September 08 15:57:49 »
is PI crashing before the installer starts? i have seen that often times the x86-64 version crashes on exit. if there was an update pending at that time it does not happen. when PI starts up again it wants to download the updates again, but i suspect they are still hanging around in whatever temp directory they were put in.
can the installer be invoked by the user somehow? is it inside the PI application bundle somewhere? if so "open -a /path/to/updater.app" might work after a PI crash on exit.
Offline AstroGabe
« Reply #4 on: 2011 September 20 15:01:02 »
I'm having the same situation.  Any progress on this?
Offline martin_magnan
    • Messager Céleste
« Reply #5 on: 2011 September 20 15:56:09 »
I have seen this behavior a few times but it occurs once or twice in a row. Not in a loop. Nothing scientific here but everytime it happens is when
1-I launch PI
2- update are available and  downloaded
3- I immediately  quit PI and the update are installed
4- PI crash
If between 2 and 3 I do some stuff in PI , like opening a few files then the update goes fine
Hope it helps
Martin
TEC140 / AP1200GTO / QSI583wsg - Astrodon LRGB 2 filters / Lodestar X2 Guider / Robofocus
http://www.messagerceleste.com
« Reply #6 on: 2011 September 21 16:04:23 »
Hi all,
I am working to fix this problem as soon as possible. Please be patient and rest assured this will be fixed.
Martin, thanks for the info. It may be important to understand the problem (a precondition to fix it) and perhaps it is a workaround while I publish a bugfix update. Can more Mac OS X users confirm that this prevents the crash on exit?
    • Messager Céleste
« Reply #7 on: 2011 September 21 17:13:25 »
You're very welcome
I should add that i'm running PixInsight Core 01.07.00.0702 Starbuck (x86_64) on OS X version 10.7
Martin
    • Messager Céleste
« Reply #8 on: 2011 September 28 18:49:08 »
Tonight there was an update (noise reduction) and it happened exactly as I describe above
update - quit - crash
update - open image - quit - update successful
Martin
« Reply #9 on: 2011 September 29 00:05:11 »
Hi Martin,
Again thanks and sorry for the trouble.
It is *essential* that more Mac OS X users report if Martin's workaround (open an image before terminating the application right before installing an update) work also for them. This is a weird error and to make it worse we cannot reproduce it, so any information is greatly appreciated.
« Reply #10 on: 2011 September 30 16:29:30 »
okay, open x86_64 version of pixinsight 1.7 under osx 10.6.8; ImageIntensity updates are available.
select updates
quit pixinsight,
pixinsight crash:
Process:         PixInsight64 [25537]
Path:            /Applications/PixInsight64.app/Contents/MacOS/PixInsight64
Identifier:      com.pleiades-astrophoto.PixInsight
Version:         ??? (01.07.00.0702 (x86_64))
Code Type:       X86-64 (Native)
Parent Process:  launchd [290]
Date/Time:       2011-09-30 16:24:28.294 -0700
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          556256 sec
Crashes Since Last Report:           11
Per-App Interval Since Last Report:  329545 sec
Per-App Crashes Since Last Report:   2
Exception Type:  EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000102417c58
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib              0x00007fff8a1670b6 __kill + 10
1   libSystem.B.dylib              0x00007fff8a2079f6 abort + 83
2   libstdc++.6.dylib              0x00007fff879875d2 __tcf_0 + 0
3   libobjc.A.dylib                0x00007fff87dadb4d _objc_terminate + 120
4   libstdc++.6.dylib              0x00007fff87985ae1 __cxxabiv1::__terminate(void (*)()) + 11
5   libstdc++.6.dylib              0x00007fff87985b16 __cxxabiv1::__unexpected(void (*)()) + 0
6   libstdc++.6.dylib              0x00007fff87985bfc __gxx_exception_cleanup(_Unwind_Reason_Code, _Unwind_Exception*) + 0
7   ...iades-astrophoto.PixInsight 0x0000000100fa20dc pcl::CriticalSignalHandler(int) + 364
8   libSystem.B.dylib              0x00007fff8a1791ba _sigtramp + 26
9   ???                            0x0000000102417c58 vtable for QScrollBar + 472
10  ...e.print.framework.PrintCore 0x00007fff8451cf20 PMGetUnadjustedPaperRect + 27
11  QtGui                          0x000000010199652d QDesktopWidget::resizeEvent(QResizeEvent*) + 32477
12  QtGui                          0x000000010199864b QDesktopWidget::resizeEvent(QResizeEvent*) + 40955
13  QtGui                          0x0000000101b4861a QPrinter::paperSize() const + 42
14  ...iades-astrophoto.PixInsight 0x0000000100a279ec pi::PixInsightPrinter::Save() const + 908
15  ...iades-astrophoto.PixInsight 0x0000000100cddcd5 main + 21845
16  ...iades-astrophoto.PixInsight 0x000000010000b838 start + 52
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib              0x00007fff8a131c0a kevent + 10
1   libSystem.B.dylib              0x00007fff8a133add _dispatch_mgr_invoke + 154
2   libSystem.B.dylib              0x00007fff8a1337b4 _dispatch_queue_invoke + 185
3   libSystem.B.dylib              0x00007fff8a1332de _dispatch_worker_thread2 + 252
4   libSystem.B.dylib              0x00007fff8a132c08 _pthread_wqthread + 353
5   libSystem.B.dylib              0x00007fff8a132aa5 start_wqthread + 13
Thread 2:
0   libSystem.B.dylib              0x00007fff8a153a6a __semwait_signal + 10
1   libSystem.B.dylib              0x00007fff8a157881 _pthread_cond_wait + 1286
2   QtCore                        0x00000001040c3f03 QThreadStorageData::finish(void**) + 867
3   QtCore                        0x00000001040c4076 QThread::msleep(unsigned long) + 150
4   ...iades-astrophoto.PixInsight 0x0000000100168f76 pi::WatchDog::run() + 198
5   QtCore                        0x00000001040c44a5 QThread::setPriority(QThread::Priority) + 453
6   libSystem.B.dylib              0x00007fff8a151fd6 _pthread_start + 331
7   libSystem.B.dylib              0x00007fff8a151e89 thread_start + 13
Thread 3:
2   QtWebKit                      0x00000001033e8908 JSValueIsInstanceOfConstructor + 1461032
3   QtWebKit                      0x00000001033e8b49 JSValueIsInstanceOfConstructor + 1461609
4   libSystem.B.dylib              0x00007fff8a151fd6 _pthread_start + 331
5   libSystem.B.dylib              0x00007fff8a151e89 thread_start + 13
Thread 4:
2   QtCore                        0x0000000104041564 QWaitCondition::wait(QMutex*, unsigned long) + 308
3   QtWebKit                      0x00000001030f7d13 qWebKitVersion() + 662467
4   QtWebKit                      0x00000001030f7ed8 qWebKitVersion() + 662920
5   QtWebKit                      0x00000001033f3c93 JSValueIsInstanceOfConstructor + 1506995
6   QtCore                        0x00000001040c44a5 QThread::setPriority(QThread::Priority) + 453
7   libSystem.B.dylib              0x00007fff8a151fd6 _pthread_start + 331
8   libSystem.B.dylib              0x00007fff8a151e89 thread_start + 13
Thread 5:
0   libSystem.B.dylib              0x00007fff8a15c932 select$DARWIN_EXTSN + 10
1   QtCore                        0x0000000104165e6d QFSFileEngine::fileName(QAbstractFileEngine::FileName) const + 15325
2   QtCore                        0x00000001040c44a5 QThread::setPriority(QThread::Priority) + 453
3   libSystem.B.dylib              0x00007fff8a151fd6 _pthread_start + 331
4   libSystem.B.dylib              0x00007fff8a151e89 thread_start + 13
Thread 6:  com.apple.CFSocket.private
1   com.apple.CoreFoundation      0x00007fff87c57498 __CFSocketManager + 824
2   libSystem.B.dylib              0x00007fff8a151fd6 _pthread_start + 331
3   libSystem.B.dylib              0x00007fff8a151e89 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00007fff7122e2f8  rcx: 0x00007fff5fbfde88  rdx: 0x0000000000000000
  rdi: 0x00000000000063c1  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfdea0  rsp: 0x00007fff5fbfde88
   r8: 0x0000000000000001   r9: 0x0000000106816d90  r10: 0x00007fff8a1630fa  r11: 0x0000000000000206
  r12: 0x0000000101124f43  r13: 0x000000012eb29660  r14: 0x00007fff5fbfe5cc  r15: 0x00007fff5fbfe850
  rip: 0x00007fff8a1670b6  rfl: 0x0000000000000206  cr2: 0x00007fff70eb0e88
Binary Images:
       0x100000000 -        0x101671fe7 +com.pleiades-astrophoto.PixInsight ??? (01.07.00.0702 (x86_64)) <23722E5E-2541-D939-D2EF-D1846DB75B9D> /Applications/PixInsight64.app/Contents/MacOS/PixInsight64
       0x101950000 -        0x1023e2fff +QtGui 4.7.3 (compatibility 4.7.0) <D8FB7C16-B1DD-1D6A-DECF-4C3160D420F8> /Applications/PixInsight64.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
       0x1025a1000 -        0x1025fbfef +QtSvg 4.7.3 (compatibility 4.7.0) <55C7EC7C-E225-ACAB-52B0-4F1D5B616D5D> /Applications/PixInsight64.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
       0x102611000 -        0x102657fef +QtXml 4.7.3 (compatibility 4.7.0) <BB0CF8ED-D3A2-114F-FA21-2415CA754D73> /Applications/PixInsight64.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
       0x102669000 -        0x103bd4fff +QtWebKit 4.7.3 (compatibility 4.7.0) <E2336234-08F1-8920-6EC2-CD207322BD40> /Applications/PixInsight64.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
       0x103eb1000 -        0x104001ff7 +QtNetwork 4.7.3 (compatibility 4.7.0) <ADCEC7B7-0C3B-F0D8-60A7-6F12F58C6DD1> /Applications/PixInsight64.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
       0x104036000 -        0x104302fe7 +QtCore 4.7.3 (compatibility 4.7.0) <E9727E3F-B65C-F0A9-22CA-021328EDC9AD> /Applications/PixInsight64.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
       0x104367000 -        0x104639fff +libmozjs185.1.0.dylib ??? (???) <5EA7F438-7150-7240-7BE0-122E2D8A5499> /Applications/PixInsight64.app/Contents/Frameworks/libmozjs185.1.0.dylib
       0x10467b000 -        0x1046b7fef +liblcms-pxi.dylib ??? (???) <A62EB0BE-4E6B-AEE3-24C0-4D8C3418B404> /Applications/PixInsight64.app/Contents/MacOS/liblcms-pxi.dylib
       0x106a8f000 -        0x106a96fff +libqgif.dylib ??? (???) <39A78A60-1237-AF9A-B15F-592B34335FE0> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x106a9a000 -        0x106aa1fff +libqico.dylib ??? (???) <5D1CB798-7591-04F7-B487-C862E9B105D3> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqico.dylib
       0x106aa6000 -        0x106ae2fef +libqjpeg.dylib ??? (???) <208173AD-07CA-845E-DC9B-6468374BBDD4> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x106ae7000 -        0x106aecff7 +libqsvg.dylib ??? (???) <87C47473-D8B2-81B9-30B3-DFD6F726F9AC> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqsvg.dylib
       0x107dae000 -        0x107e0afe7 +libqmng.dylib ??? (???) <0826A2CB-25AC-981C-057A-952862DC4361> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqmng.dylib
       0x107e12000 -        0x107e68ff7 +libqtiff.dylib ??? (???) <512CFCAB-4222-510F-514C-D1B6CAAACA18> /Applications/PixInsight64.app/Contents/PlugIns/imageformats/libqtiff.dylib
       0x11d261000 -        0x11d27bfff +libqcorewlanbearer.dylib ??? (???) <EA49165F-7896-90B3-5577-B375497EBD60> /Applications/PixInsight64.app/Contents/PlugIns/bearer/libqcorewlanbearer.dylib
       0x11d284000 -        0x11d2bdff7  com.apple.coreWLAN.framework 6.2.5 (625.6) <45E3431E-B30A-B844-3DF1-A1F4FA1AAB19> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
       0x11d2d6000 -        0x11d2e2fff +libqgenericbearer.dylib ??? (???) <08484BAF-6154-4C43-B671-818A52AC2B0A> /Applications/PixInsight64.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
       0x11d2e8000 -        0x11d30bfef +libqcncodecs.dylib ??? (???) <418D3694-4B4B-4C38-3F56-D84DD8C0F9FC> /Applications/PixInsight64.app/Contents/PlugIns/codecs/libqcncodecs.dylib
       0x11d30f000 -        0x11d339ff7 +libqjpcodecs.dylib ??? (???) <10AF1487-029A-DF1E-9024-10AF2D3734C3> /Applications/PixInsight64.app/Contents/PlugIns/codecs/libqjpcodecs.dylib
       0x11d33f000 -        0x11d352fe7 +libqkrcodecs.dylib ??? (???) <644AA2F8-2CCF-178F-762F-7809DA0481C7> /Applications/PixInsight64.app/Contents/PlugIns/codecs/libqkrcodecs.dylib
       0x11d356000 -        0x11d37cfff +libqtwcodecs.dylib ??? (???) <5F744514-4459-D9B4-9645-EF3B1B777BF7> /Applications/PixInsight64.app/Contents/PlugIns/codecs/libqtwcodecs.dylib
       0x11f5de000 -        0x11f5f3ff7 +libzlib-pxi.dylib ??? (???) <AA12E8E1-611E-273F-58B9-4289F797A7F8> /Applications/PixInsight64.app/Contents/MacOS/libzlib-pxi.dylib
       0x122a00000 -        0x122c55ff7 +Annotation-pxm.dylib ??? (???) <139B28AE-8B29-71C7-2861-840AD6C70B5E> /Applications/PixInsight64.app/Contents/MacOS/Annotation-pxm.dylib
       0x122caf000 -        0x122ef0fef +AssistedColorCalibration-pxm.dylib ??? (???) <6B97124C-FD05-999B-F681-DBF58C4B38D6> /Applications/PixInsight64.app/Contents/MacOS/AssistedColorCalibration-pxm.dylib
       0x123010000 -        0x123306fff +BackgroundModelization-pxm.dylib ??? (???) <7C73A60B-9F7F-F40D-79D0-78702CC27A4E> /Applications/PixInsight64.app/Contents/MacOS/BackgroundModelization-pxm.dylib
       0x123600000 -        0x123838fef +BMP-pxm.dylib ??? (???) <5D90DFDF-690D-E0F5-891F-CC8845B43221> /Applications/PixInsight64.app/Contents/MacOS/BMP-pxm.dylib
       0x1238e5000 -        0x123cc1fef +CloneStamp-pxm.dylib ??? (???) <F36D43FE-BAD6-B1B9-875B-02C90063FDCA> /Applications/PixInsight64.app/Contents/MacOS/CloneStamp-pxm.dylib
       0x123ec9000 -        0x1241cdff7 +ColorCalibration-pxm.dylib ??? (???) <FE307C95-4596-5BB6-B2AF-6547FEC1134B> /Applications/PixInsight64.app/Contents/MacOS/ColorCalibration-pxm.dylib
       0x124500000 -        0x124766fef +ColorManagement-pxm.dylib ??? (???) <023CB09A-6BF2-94B4-5564-A97A55C13864> /Applications/PixInsight64.app/Contents/MacOS/ColorManagement-pxm.dylib
       0x124847000 -        0x124e44fef +ColorSpaces-pxm.dylib ??? (???) <6DB254CE-95A0-03E6-1E8D-41B804C55786> /Applications/PixInsight64.app/Contents/MacOS/ColorSpaces-pxm.dylib
       0x125015000 -        0x125328fff +Compatibility-pxm.dylib ??? (???) <64367CDD-FF28-B267-E85B-26E2D6BDE933> /Applications/PixInsight64.app/Contents/MacOS/Compatibility-pxm.dylib
       0x125600000 -        0x125991ff7 +Convolution-pxm.dylib ??? (???) <2F5D0AE2-2F48-ACC1-111B-9A53AC138C04> /Applications/PixInsight64.app/Contents/MacOS/Convolution-pxm.dylib
       0x125aeb000 -        0x125d18ff7 +Debayer-pxm.dylib ??? (???) <789F9E55-7860-EDB0-BB52-338E7BA547E4> /Applications/PixInsight64.app/Contents/MacOS/Debayer-pxm.dylib
       0x125e74000 -        0x1261a5fff +Deconvolution-pxm.dylib ??? (???) <F7604608-0126-D0BC-6768-6EDA45F1781D> /Applications/PixInsight64.app/Contents/MacOS/Deconvolution-pxm.dylib
       0x12632f000 -        0x1265bfff7 +DSLR_RAW-pxm.dylib ??? (???) <F249D92A-7807-7DC1-2910-E2CBB18871D4> /Applications/PixInsight64.app/Contents/MacOS/DSLR_RAW-pxm.dylib
       0x1266f1000 -        0x12697efef +FITS-pxm.dylib ??? (???) <485D93CB-E3DB-3D7F-9843-D58F4C2CD9F7> /Applications/PixInsight64.app/Contents/MacOS/FITS-pxm.dylib
       0x1269dd000 -        0x126b22fe7 +libcfitsio-pxi.dylib ??? (???) <3BCA5A3B-4E8E-FFD3-9E95-35C45677740E> /Applications/PixInsight64.app/Contents/MacOS/libcfitsio-pxi.dylib
       0x126c17000 -        0x126e8cfff +Fourier-pxm.dylib ??? (???) <E392DC71-3DF0-95B2-BEBD-CE03501BCA7A> /Applications/PixInsight64.app/Contents/MacOS/Fourier-pxm.dylib
       0x127100000 -        0x12740efe7 +Geometry-pxm.dylib ??? (???) <B9FAEBAE-8974-EDCD-9200-576DF8FBF843> /Applications/PixInsight64.app/Contents/MacOS/Geometry-pxm.dylib
       0x1275a5000 -        0x1278defff +Global-pxm.dylib ??? (???) <F307B67A-BEBB-9C18-0D9B-7AE6BF08F869> /Applications/PixInsight64.app/Contents/MacOS/Global-pxm.dylib
       0x127c00000 -        0x127e75fef +GREYCstoration-pxm.dylib ??? (???) <F9E1E93A-89E8-10DF-8B96-19FC3FE47A79> /Applications/PixInsight64.app/Contents/MacOS/GREYCstoration-pxm.dylib
       0x128100000 -        0x1284d9fe7 +Image-pxm.dylib ??? (???) <0BA46EF0-F0CB-1DD5-304F-E063A24B4B5C> /Applications/PixInsight64.app/Contents/MacOS/Image-pxm.dylib
       0x128800000 -        0x128b50fe7 +ImageCalibration-pxm.dylib ??? (???) <7109F71B-1266-EF9A-F03F-EA6279E15F58> /Applications/PixInsight64.app/Contents/MacOS/ImageCalibration-pxm.dylib
       0x128c53000 -        0x129003ff7 +ImageIntegration-pxm.dylib ??? (???) <9A619CC5-E43D-DE87-6F59-B437CDF55DA1> /Applications/PixInsight64.app/Contents/MacOS/ImageIntegration-pxm.dylib
       0x129163000 -        0x12971bff7 +ImageRegistration-pxm.dylib ??? (???) <7FBBD2C7-EE5D-5517-838E-A7FCA96D1ED7> /Applications/PixInsight64.app/Contents/MacOS/ImageRegistration-pxm.dylib
       0x1298f4000 -        0x129cf9ff7 +IntensityTransformations-pxm.dylib ??? (???) <AEA081CC-0BBC-4A1A-9A3A-78F28CE429BC> /Applications/PixInsight64.app/Contents/MacOS/IntensityTransformations-pxm.dylib
       0x12a000000 -        0x12a25bff7 +JPEG-pxm.dylib ??? (???) <DBB8C44D-2C61-0DC3-9A38-670F89FB6CB9> /Applications/PixInsight64.app/Contents/MacOS/JPEG-pxm.dylib
       0x12a2b4000 -        0x12a2eaff7 +libjpeg-pxi.dylib ??? (???) <F58C97F8-E0DD-6C02-F5D2-1CDEAD2E336A> /Applications/PixInsight64.app/Contents/MacOS/libjpeg-pxi.dylib
       0x12a371000 -        0x12a5d1fef +JPEG2000-pxm.dylib ??? (???) <180B4EAC-D36C-494B-E852-D1EE11C5C359> /Applications/PixInsight64.app/Contents/MacOS/JPEG2000-pxm.dylib
       0x12a629000 -        0x12a663fff +libjasper-pxi.dylib ??? (???) <6C23C506-ECEB-F594-7652-251B27AFAB12> /Applications/PixInsight64.app/Contents/MacOS/libjasper-pxi.dylib
       0x12a6f7000 -        0x12a946ff7 +LocalHistogramEqualization-pxm.dylib ??? (???) <781E16C7-1426-5B88-3D8E-3628AF8BF60C> /Applications/PixInsight64.app/Contents/MacOS/LocalHistogramEqualization-pxm.dylib
       0x12abad000 -        0x12aec9fff +MaskGeneration-pxm.dylib ??? (???) <2D295F8B-31D9-011C-1192-2CE0D10988D3> /Applications/PixInsight64.app/Contents/MacOS/MaskGeneration-pxm.dylib
       0x12b200000 -        0x12b49cfff +Morphology-pxm.dylib ??? (???) <6585FAD9-F968-1338-15DE-98ACD118F74D> /Applications/PixInsight64.app/Contents/MacOS/Morphology-pxm.dylib
       0x12b800000 -        0x12ba44ff7 +NoiseGeneration-pxm.dylib ??? (???) <03C5C6D8-317B-2A89-AA60-6175DF3F4ECD> /Applications/PixInsight64.app/Contents/MacOS/NoiseGeneration-pxm.dylib
       0x12bb68000 -        0x12be98fff +NoiseReduction-pxm.dylib ??? (???) <78C9B0E7-A713-2352-FB1B-91DCDBB401BE> /Applications/PixInsight64.app/Contents/MacOS/NoiseReduction-pxm.dylib
       0x12bfa2000 -        0x12c1a4ff7 +NoOperation-pxm.dylib ??? (???) <A31F4A26-D2DB-DCE3-4351-5DA16D1717C2> /Applications/PixInsight64.app/Contents/MacOS/NoOperation-pxm.dylib
       0x12c273000 -        0x12c555fe7 +Obsolete-pxm.dylib ??? (???) <E346CE2B-707B-3F4C-0088-3090BD790BBE> /Applications/PixInsight64.app/Contents/MacOS/Obsolete-pxm.dylib
       0x12c75a000 -        0x12ca63fef +PixelMath-pxm.dylib ??? (???) <2B101218-06DD-07DC-EA5C-495766B03420> /Applications/PixInsight64.app/Contents/MacOS/PixelMath-pxm.dylib
       0x12cbf1000 -        0x12cec1fe7 +RestorationFilters-pxm.dylib ??? (???) <A82958C5-D721-A62B-CAB4-1F82AFD3E357> /Applications/PixInsight64.app/Contents/MacOS/RestorationFilters-pxm.dylib
       0x12d03e000 -        0x12d26ffef +Sandbox-pxm.dylib ??? (???) <C2D6F354-D8CA-CC50-200B-C699EC82C7C7> /Applications/PixInsight64.app/Contents/MacOS/Sandbox-pxm.dylib
       0x12d3ca000 -        0x12d652ff7 +StarGenerator-pxm.dylib ??? (???) <F754FFBC-1AC8-AF4D-9D54-6213A2D93601> /Applications/PixInsight64.app/Contents/MacOS/StarGenerator-pxm.dylib
       0x12d7bd000 -        0x12da4fff7 +TIFF-pxm.dylib ??? (???) <AAC0F20C-E6D9-7412-C396-E4E5E9853F32> /Applications/PixInsight64.app/Contents/MacOS/TIFF-pxm.dylib
       0x12daaa000 -        0x12db05fe7 +liblibtiff-pxi.dylib ??? (???) <30C4ECC2-33B9-910B-56E9-2E295444352C> /Applications/PixInsight64.app/Contents/MacOS/liblibtiff-pxi.dylib
       0x12db93000 -        0x12deafff7 +Wavelets-pxm.dylib ??? (???) <505425AD-339E-37FF-DA8B-98FA69DF3621> /Applications/PixInsight64.app/Contents/MacOS/Wavelets-pxm.dylib
       0x12e0c1000 -        0x12e3adfe7 +2011_07_31_Gradients-pxm.dylib ??? (???) <71287D72-7D03-C034-42B7-080DD0775569> /Volumes/newLeopard/Users/pfile/src/PCL/bin/2011_07_31_Gradients-pxm.dylib
    0x7fff5fc00000 -     0x7fff5fc3bdef  dyld 132.1 (???) <69130DA3-7CB3-54C8-ABC5-423DECDD2AF7> /usr/lib/dyld
    0x7fff80061000 -     0x7fff8009cfff  com.apple.AE 496.5 (496.5) <208DF391-4DE6-81ED-C697-14A2930D1BC6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff8009d000 -     0x7fff800e7ff7  com.apple.Metadata 10.6.3 (507.15) <2EF19055-D7AE-4D77-E589-7B71B0BC1E59> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff800e8000 -     0x7fff8036afe7  com.apple.Foundation 6.6.7 (751.62) <6F2A5BBF-6990-D561-2928-AD61E94036D9> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff8036b000 -     0x7fff8036bff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <15DF8B4A-96B2-CB4E-368D-DEC7DF6B62BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff803ea000 -     0x7fff8071efef  com.apple.CoreServices.CarbonCore 861.39 (861.39) <1386A24D-DD15-5903-057E-4A224FAF580B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff8071f000 -     0x7fff80724ff7  com.apple.CommonPanels 1.2.4 (91) <4D84803B-BD06-D80E-15AE-EFBE43F93605> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff807ad000 -     0x7fff807b8ff7  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <3D65E89B-FFC6-4AAF-D5CC-104F967C8131> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff80a14000 -     0x7fff80a19fff  libGIF.dylib ??? (???) <201B8077-B5CC-11AA-E1B0-1D057ABE416A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff80a1a000 -     0x7fff80b58fff  com.apple.CoreData 102.1 (251) <9DFE798D-AA52-6A9A-924A-DA73CB94D81A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff80bc3000 -     0x7fff80bebfff  com.apple.DictionaryServices 1.1.2 (1.1.2) <E9269069-93FA-2B71-F9BA-FDDD23C4A65E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff80bec000 -     0x7fff80bfbfef  com.apple.opengl 1.6.13 (1.6.13) <516098B3-4517-8A55-64BB-195CDAA5334D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff80bfc000 -     0x7fff81406fe7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <FC941ECB-71D0-FAE3-DCBF-C5A619E594B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff81407000 -     0x7fff8140dff7  com.apple.DiskArbitration 2.3 (2.3) <857F6E43-1EF4-7D53-351B-10DE0A8F992A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff81553000 -     0x7fff81559ff7  com.apple.CommerceCore 1.0 (9.1) <3691E9BA-BCF4-98C7-EFEC-78DA6825004E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x7fff815e8000 -     0x7fff81652fe7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <AF0EA96D-000F-8C12-B952-CB7E00566E08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff81653000 -     0x7fff8170cfff  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <2C5ED312-E646-9ADE-73A9-6199A2A43150> /usr/lib/libsqlite3.dylib
    0x7fff8191f000 -     0x7fff8191fff7  com.apple.CoreServices 44 (44) <DC7400FB-851E-7B8A-5BF6-6F50094302FB> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff8199d000 -     0x7fff819e0ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <5FF3D7FD-84D8-C5FA-D640-90BB82EC651D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff819e1000 -     0x7fff81c6aff7  com.apple.security 6.1.2 (55002) <4419AFFC-DAE7-873E-6A7D-5C9A5A4497A6> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff81c6b000 -     0x7fff81f69fff  com.apple.HIToolbox 1.6.5 (???) <AD1C18F6-51CB-7E39-35DD-F16B1EB978A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff81f6a000 -     0x7fff82027fff  com.apple.CoreServices.OSServices 359.2 (359.2) <BBB8888E-18DE-5D09-3C3A-F4C029EC7886> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff82028000 -     0x7fff820a6ff7  com.apple.CoreText 151.10 (???) <54961997-55D8-DC0F-2634-674E452D5A8E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff820a7000 -     0x7fff820acfff  libGFXShared.dylib ??? (???) <1D0D3531-9561-632C-D620-1A8652BEF5BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff820af000 -     0x7fff820e2ff7  libTrueTypeScaler.dylib ??? (???) <69D4A213-45D2-196D-7FF8-B52A31DFD329> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff825a1000 -     0x7fff825a5ff7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <95718673-FEEE-B6ED-B127-BCDBDB60D4E5> /usr/lib/system/libmathCommon.A.dylib
    0x7fff825a6000 -     0x7fff825a6ff7  com.apple.Carbon 150 (152) <C0E61968-57F3-6EE1-8524-32A18955BAF0> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff825a7000 -     0x7fff825b8ff7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <97019C74-161A-3488-41EC-A6CA8738418C> /usr/lib/libz.1.dylib
    0x7fff82633000 -     0x7fff82682ff7  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <01B370FB-D524-F660-3826-E85B7F0D85CD> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x7fff8273b000 -     0x7fff8274fff7  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <621B7415-A0B9-07A7-F313-36BEEDD7B132> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff82750000 -     0x7fff82756ff7  IOSurface ??? (???) <6AF28EC1-BCC4-9F65-AF7D-ABE60B91072A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff82757000 -     0x7fff82772ff7  com.apple.openscripting 1.3.1 (???) <9D50701D-54AC-405B-CC65-026FCB28258B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff82773000 -     0x7fff82774fff  liblangid.dylib ??? (???) <EA4D1607-2BD5-2EE2-2A3B-632EEE5A444D> /usr/lib/liblangid.dylib
    0x7fff8278b000 -     0x7fff828aafe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <14115D29-432B-CF02-6B24-A60CC533A09E> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff828ab000 -     0x7fff828b8fe7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <1C35FA50-9C70-48DC-9E8D-2054F7A266B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x7fff828b9000 -     0x7fff82949fff  com.apple.SearchKit 1.3.0 (1.3.0) <4175DC31-1506-228A-08FD-C704AC9DF642> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff82956000 -     0x7fff82976ff7  com.apple.DirectoryService.Framework 3.6 (621.11) <AD76C757-6701-BDB5-631E-1CB77D669586> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff82977000 -     0x7fff829c6fef  libTIFF.dylib ??? (???) <1E2593D1-A7F6-84C6-DF8F-0B46AE445926> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff82f88000 -     0x7fff83049fef  com.apple.ColorSync 4.6.6 (4.6.6) <BB2C5813-C61D-3CBA-A8F7-0E59E46EBEE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff83055000 -     0x7fff83056ff7  com.apple.TrustEvaluationAgent 1.1 (1) <5952A9FA-BC2B-16EF-91A7-43902A5C07B6> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff83057000 -     0x7fff83066fff  com.apple.NetFS 3.2.2 (3.2.2) <7CCBD70E-BF31-A7A7-DB98-230687773145> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff83067000 -     0x7fff8314cfef  com.apple.DesktopServices 1.5.11 (1.5.11) <39FAA3D2-6863-B5AB-AED9-92D878EA2438> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff8314d000 -     0x7fff83162ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <1AE1FE8F-2204-4410-C94E-0E93B003BEDA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff83391000 -     0x7fff833a7fef  libbsm.0.dylib ??? (???) <42D3023A-A1F7-4121-6417-FCC6B51B3E90> /usr/lib/libbsm.0.dylib
    0x7fff833a8000 -     0x7fff83427fe7  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <79E256EB-43F1-C7AA-6436-124A4FFB02D0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff83870000 -     0x7fff838bcfff  libauto.dylib ??? (???) <F7221B46-DC4F-3153-CE61-7F52C8C293CF> /usr/lib/libauto.dylib
    0x7fff838bd000 -     0x7fff83949fef  SecurityFoundation ??? (???) <8A74D45E-9FE9-DD58-42F5-C7474FFDD0C1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff8397a000 -     0x7fff839b4fff  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <539EBFDD-96D6-FB07-B128-40232C408757> /usr/lib/libcups.2.dylib
    0x7fff839b5000 -     0x7fff83d52fe7  com.apple.QuartzCore 1.6.3 (227.37) <16DFF6CD-EA58-CE62-A1D7-5F6CE3D066DD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff83db4000 -     0x7fff844b0ff7  com.apple.CoreGraphics 1.545.0 (???) <58D597B1-EB3B-710E-0B8C-EC114D54E11B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff844b1000 -     0x7fff844c7fe7  com.apple.MultitouchSupport.framework 207.11 (207.11) <8233CE71-6F8D-8B3C-A0E1-E123F6406163> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff84512000 -     0x7fff84597ff7  com.apple.print.framework.PrintCore 6.3 (312.7) <CDFE82DD-D811-A091-179F-6E76069B432D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff84598000 -     0x7fff84659fff  libFontParser.dylib ??? (???) <A00BB0A7-E46C-1D07-1391-194745566C7E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff8465a000 -     0x7fff85054ff7  com.apple.AppKit 6.6.8 (1038.36) <4CFBE04C-8FB3-B0EA-8DDB-7E7D10E9D251> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff850be000 -     0x7fff850effff  libGLImage.dylib ??? (???) <7F102A07-E4FB-9F52-B2F6-4E2D2383CA13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff850f0000 -     0x7fff850feff7  libkxld.dylib ??? (???) <8145A534-95CC-9F3C-B78B-AC9898F38C6F> /usr/lib/system/libkxld.dylib
    0x7fff851ab000 -     0x7fff851f2ff7  com.apple.coreui 2 (114) <923E33CC-83FC-7D35-5603-FB8F348EE34B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff851f3000 -     0x7fff85328fff  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <E5D7DBDB-6DDF-E6F9-C71C-86F4520EE5A3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff85329000 -     0x7fff85350ff7  libJPEG.dylib ??? (???) <46A413EA-4FD1-A050-2EF0-6279F3EAD581> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff85b7b000 -     0x7fff85ba6ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <8AB4CA9E-435A-33DA-7041-904BA7FA11D5> /usr/lib/libxslt.1.dylib
    0x7fff85bdd000 -     0x7fff85bdeff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <53299948-2554-0F8F-7501-04B34E49F6CF> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff85bdf000 -     0x7fff85bf6fff  com.apple.ImageCapture 6.1 (6.1) <79AB2131-2A6C-F351-38A9-ED58B25534FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff85c7a000 -     0x7fff85cb7ff7  libFontRegistry.dylib ??? (???) <4C3293E2-851B-55CE-3BE3-29C425DD5DFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff86d83000 -     0x7fff86d97fff  libGL.dylib ??? (???) <2ECE3B0F-39E1-3938-BF27-7205C6D0358B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff86d98000 -     0x7fff86e4dfe7  com.apple.ink.framework 1.3.3 (107) <8C36373C-5473-3A6A-4972-BC29D504250F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff86e4e000 -     0x7fff8700cff7  com.apple.ImageIO.framework 3.0.4 (3.0.4) <0A4F51A1-4502-767B-8A4E-F14C6214EF88> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff87087000 -     0x7fff870a0fff  com.apple.CFOpenDirectory 10.6 (10.6) <401557B1-C6D1-7E1A-0D7E-941715C37BFA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff870a1000 -     0x7fff874e4fef  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <0CC61C98-FF51-67B3-F3D8-C5E430C201A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff874e5000 -     0x7fff875fcfef  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <1B27AFDD-DF87-2009-170E-C129E1572E8B> /usr/lib/libxml2.2.dylib
    0x7fff877d4000 -     0x7fff8781cff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <98FC4457-F405-0262-00F7-56119CA107B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff8782d000 -     0x7fff8784aff7  libPng.dylib ??? (???) <6D8E515B-E0A2-2BA1-9CAC-8CB8A8B35879> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff87895000 -     0x7fff87895ff7  com.apple.ApplicationServices 38 (38) <10A0B9E9-4988-03D4-FC56-DDE231A02C63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff878e2000 -     0x7fff87935ff7  com.apple.HIServices 1.8.3 (???) <F6E0C7A7-C11D-0096-4DDA-2C77793AA6CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff87936000 -     0x7fff8793aff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <DB710299-B4D9-3714-66F7-5D2964DE585B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff8793b000 -     0x7fff879b8fef  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <35ECA411-2C08-FD7D-11B1-1B7A04921A5C> /usr/lib/libstdc++.6.dylib
    0x7fff879b9000 -     0x7fff879dcfff  com.apple.opencl 12.3.6 (12.3.6) <42FA5783-EB80-1168-4015-B8C68F55842F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff879dd000 -     0x7fff879e0ff7  libCoreVMClient.dylib ??? (???) <E03D7C81-A3DA-D44A-A88A-DDBB98AF910B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff87a11000 -     0x7fff87a11ff7  com.apple.vecLib 3.6 (vecLib 3.6) <96FB6BAD-5568-C4E0-6FA7-02791A58B584> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff87a12000 -     0x7fff87a15ff7  com.apple.securityhi 4.0 (36638) <EABABBA8-AB59-599A-1884-0010C059DE62> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff87aef000 -     0x7fff87aefff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <4CCE5D69-F1B3-8FD3-1483-E0271DB2CCF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff87af0000 -     0x7fff87be8ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <44AADE50-15BC-BC6B-BEF0-5029A30766AC> /usr/lib/libiconv.2.dylib
    0x7fff87be9000 -     0x7fff87d60fe7  com.apple.CoreFoundation 6.6.5 (550.43) <31A1C118-AD96-0A11-8BDF-BD55B9940EDC> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff87da0000 -     0x7fff87e56ff7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <03140531-3B2D-1EBA-DA7F-E12CC8F63969> /usr/lib/libobjc.A.dylib
    0x7fff87e65000 -     0x7fff87ea6fff  com.apple.SystemConfiguration 1.10.8 (1.10.2) <78D48D27-A9C4-62CA-2803-D0BBED82855A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff87fbb000 -     0x7fff88179fff  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <4274FC73-A257-3A56-4293-5968F3428854> /usr/lib/libicucore.A.dylib
    0x7fff884f8000 -     0x7fff88592fe7  com.apple.ApplicationServices.ATS 275.16 (???) <4B70A2FC-1902-5F27-5C3B-5C78C283C6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff8864e000 -     0x7fff88697fef  libGLU.dylib ??? (???) <1C050088-4AB2-2BC2-62E6-C969F925A945> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff88698000 -     0x7fff8876cfe7  com.apple.CFNetwork 454.12.4 (454.12.4) <C83E2BA1-1818-B3E8-5334-860AD21D1C80> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff887a8000 -     0x7fff88848fff  com.apple.LaunchServices 362.3 (362.3) <B90B7C31-FEF8-3C26-BFB3-D8A48BD2C0DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff88aa8000 -     0x7fff88b73fff  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <E72880D9-3B5D-D086-9266-F4F3C294619F> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x7fff88b74000 -     0x7fff88b86fe7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <76B83C8D-8EFE-4467-0F75-275648AFED97> /usr/lib/libsasl2.2.dylib
    0x7fff88b92000 -     0x7fff88bf2fe7  com.apple.framework.IOKit 2.0 (???) <4F071EF0-8260-01E9-C641-830E582FA416> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff88bf3000 -     0x7fff88bfafff  com.apple.OpenDirectory 10.6 (10.6) <4FF6AD25-0916-B21C-9E88-2CC42D90EAC7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff88c78000 -     0x7fff88c99fff  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <9F322F47-0584-CB7D-5B73-9EBD670851CD> /usr/lib/libresolv.9.dylib
    0x7fff89225000 -     0x7fff892d5fff  edu.mit.Kerberos 6.5.11 (6.5.11) <085D80F5-C9DC-E252-C21B-03295E660C91> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff892ef000 -     0x7fff892f1fff  com.apple.print.framework.Print 6.1 (237.1) <CA8564FB-B366-7413-B12E-9892DA3C6157> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff892f2000 -     0x7fff893cffff  com.apple.vImage 4.1 (4.1) <C3F44AA9-6F71-0684-2686-D3BBC903F020> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff89d54000 -     0x7fff89e6efef  libGLProgrammability.dylib ??? (???) <8A4B86E3-0FA7-8684-2EF2-C5F8079428DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff8a0aa000 -     0x7fff8a0adfff  com.apple.help 1.3.2 (41.1) <BD1B0A22-1CB8-263E-FF85-5BBFDE3660B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff8a0ae000 -     0x7fff8a103ff7  com.apple.framework.familycontrols 2.0.2 (2020) <F09541B6-5E28-1C01-C1AE-F6A2508670C7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x7fff8a118000 -     0x7fff8a2d9fef  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
    0x7fff8a320000 -     0x7fff8a322fff  libRadiance.dylib ??? (???) <A9DB4D5D-4072-971B-DEF6-DDE645F415EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff8a323000 -     0x7fff8a364fef  com.apple.QD 3.36 (???) <5DC41E81-32C9-65B2-5528-B33E934D5BB4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff8a3a9000 -     0x7fff8a3a9ff7  com.apple.Cocoa 6.6 (???) <68B0BE46-6E24-C96F-B341-054CF9E8F3B6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff8a632000 -     0x7fff8a657ff7  com.apple.CoreVideo 1.6.2 (45.6) <E138C8E7-3CB6-55A9-0A2C-B73FE63EA288> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffffe00000 -     0x7fffffe01fff  libSystem.B.dylib ??? (???) <9AB4F1D1-89DC-0E8A-DC8E-A4FE4D69DB69> /usr/lib/libSystem.B.dylib
kind of an odd backtrace there on thread 0. do you want me to attach gdb and get more info after the crash? let me know.
« Reply #11 on: 2011 September 30 16:37:32 »
well okay i did it again after attaching with gdb and the crash looks similar but slightly different...
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: 13 at address: 0x0000000000000000
0x00007fff845151ff in OpaquePMPageFormat::PJCValidPageFormatKey ()
(gdb) where
#0  0x00007fff845151ff in OpaquePMPageFormat::PJCValidPageFormatKey ()
#1  0x00007fff8451cf20 in PMGetUnadjustedPaperRect ()
#2  0x000000010199652d in QDesktopWidget::resizeEvent ()
#3  0x000000010199864b in QDesktopWidget::resizeEvent ()
#4  0x0000000101b4861a in QPrinter::paperSize ()
#5  0x0000000100a279ec in pi::PixInsightPrinter::Save ()
#6  0x0000000100cddcd5 in main ()
perhaps you need to have a printer installed and set to default for this bug to happen. i definitely do - an hp officejet connected via ethernet.
edit: additionally, quitting gdb from here allowed the update to happen. so i guess i can't reproduce this again unless you tell me how to trick PI into thinking it needs to install an update.
« Reply #12 on: 2011 October 01 00:47:36 »
Hi Rob,
This seems to provide some hints about the problem:
Looks like the problem is in a call to QPrinter::paperSize() from PixInsightPrinter, although the call to QDesktopWidget::resizeEvent() is strange. Your second report:
seems to confirm that the problem is in printer code, so I'll follow this path. I have also network printers and the problem doesn't happen, so it must be something more 'basic'; perhaps a Qt bug. This is a nasty bug that is damaging PixInsight's reputation on Mac OS X so I have to fix it urgently. If only I could reproduce it...
Thanks a lot for your help. I hope to get this ironed out soon!
    • Messager Céleste
« Reply #13 on: 2011 October 02 19:21:53 »
It occurs only on quit so I would not call it nasty. It's not like a crash in the middle of an intense process when you loose everything.
I would call PixInsight bad habit of jumping in front of other windows a "nasty bug". Like when you do something like Batch Debayer on 200 files and would like to do something else in the meantime (listening to a video tutorial for example). I dont know if it's Mac specific but even if I hide PixInsight it still shows up.
But having something as powerful as PI running on the Mac make me forget about every glitches.
Martin
« Reply #14 on: 2011 October 02 19:42:44 »
i think i reported this "foregrounding" behavior as well but juan could not reproduce it. it seems to have gotten less bad, but it is still there. it only seems to happen when running scripts, and if i start the script and move to another workspace or put another app in the foreground, then PI stays put until i happen to click on PI again. after that every time the script iterates, PI comes to the foreground.
