Author Topic: Brain dead, I think  (Read 40792 times)
Offline dsnay
Re: Brain dead, I think
« Reply #30 on: 2011 January 19 14:12:33 »
To be clear, there is plenty of data in the files I'm using. Here is the result of very little processing of the RGB files using PixInsight:
Dave
Offline Harry page
« Reply #31 on: 2011 January 19 14:23:49 »
I am running vista 64 , I do not know if there is a problem with windows 7 , anybody else had a problem
Harry
Harry Page
Offline sleshin
« Reply #32 on: 2011 January 19 14:48:14 »
PI works fine for me on a Win 7 64 bit machine.
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline dsnay
« Reply #33 on: 2011 January 19 16:05:28 »
Have you tried the LRGB Combine and/or the Luminance extraction tools?
And what version of PI are you using?
Dave
Offline sleshin
« Reply #34 on: 2011 January 19 18:46:58 »
I use the latest version of PI. My routine is to create the LRGB image by combining processed and then Histogram stretched master RGB and Lum images with the LRGB combine module. I am also using the Linear Fit tool to prepare the Lum image before combining it with the RGB master as described by Juan and nicely demonstrated by Harry in his video tutorial. All works properly. Your problem seems very strange and must be quite frustrating. Hope you get it worked out soon.
Steve Leshin
Sedona, Arizona
Offline Harry page
« Reply #35 on: 2011 January 20 09:30:32 »
Are you able to do a screen capture to show us what the problem is  :sad:
Harry
Harry Page
Offline dsnay
« Reply #36 on: 2011 January 20 11:57:15 »
Harry
Do you want a video capture or a simple screenshot?
Offline Harry page
« Reply #37 on: 2011 January 20 12:01:58 »
A little video to show the steps you are doing
Harry
Harry Page
astropixel
  • Guest
« Reply #38 on: 2011 January 20 12:14:11 »
I experienced the same. Similarly, couldn't get LRGBCombination to work, so reverted to ChannelCombination with linear images to avoid the difficulties (please disregard earlier reference to RGBWorking space - deleted), applying the L* combination as described by Juan earlier.
Offline dsnay
« Reply #39 on: 2011 January 20 13:29:03 »
Harry
I've made a short video, but my web space server doesn't let me put .swf files on there. (I'm definitely switching services soon.) Anybody got a way to let me post the video?
Actually, I might have it worked out. Try this:  http://www.screencast.com/users/dsnay/folders/Default/media/3c9dccaa-4c42-4610-81b5-40c105e48e76
Dave
« Last Edit: 2011 January 20 13:49:45 by dsnay »
Offline Harry page
« Reply #40 on: 2011 January 20 13:49:00 »
Upload it to my FTP server and I will stick it up for you
Harry
Harry Page
Offline Andres.Pozo
« Reply #41 on: 2011 January 21 03:47:21 »
Dave
In your video it is clear that you are doing the LRGB combination using linear images. You have to stretch the RGB and L images before applying the LRGB combination.
Offline dsnay
« Reply #42 on: 2011 January 21 06:43:35 »
Dave
As I said earlier, I've tried this with both linear and with stretched data and end up with the same black file.
Dave
Offline Harry page
« Reply #43 on: 2011 January 21 10:08:22 »
As said this video is done with linear images and won't work ( as you may know )
I think you need to show that it fails with stretched images ( another video ) and if it fails there Juan will have to take note
You may be correct and there is a problem , but I think we need to rule out the easy stuff first ;D
Regards Harry
Harry Page
Offline dsnay
« Reply #44 on: 2011 January 21 11:12:07 »
Okay, here it is: http://www.screencast.com/users/dsnay/folders/Jing/media/99781ec7-2991-453a-ab38-1cdd29d66a28
As I said, there is a problem here. I have tried this using Harry's original LRGBCombination video tutorial as well as the one he made for me using the new linear fit tool.
For this video I went with the original method only because it was quicker and I didn't want to make a huge video.
Dave
