Author Topic: Brain dead, I think  (Read 34815 times)
Offline Harry page
Re: Brain dead, I think
« Reply #45 on: 2011 January 21 11:47:48 »
Ok I think you need to remove the brain dead bit I copied what you did exactly and do not get the result you do  :footinmouth:
So Lord Juan is going to have to chip in as I can not see what is wrong ,  I know you have tried a fresh install , have you tried installing to a fresh location after uninstalling the old program ?
Harry
sorry for doubting you  ::)
Harry Page
Offline David Raphael
    • Astrofactors CCD Cameras
« Reply #46 on: 2011 January 21 22:44:54 »
Oh...BTW - I am running Windows 7 - 64 Bit // That's what I made the screencast with with Dave's data....it is definitely something specific to Dave's environment.
David Raphael
Offline dsnay
« Reply #47 on: 2011 January 24 07:43:40 »
Should I assume that since nobody else has chimed in here that there is no solution to my problem? It can't be just my laptop because I have the exact same problem on my desktop installation using the same methods and data files.
Dave
« Reply #48 on: 2011 January 24 08:11:20 »
Hi Dave,
Not at all. "No solution" is something that doesn't exist here.
The first thing we have to do is identifying the problem. This requires a simplified test. Please do the following:
1. From the Start menu, select: All Programs > PixInsight Platform > Reset PixInsight Settings. Answer yes to the question "Are you sure...". Now we have reset the whole set of PixInsight settings.
2. Start the PixInsight Core application.
3. Select Image > New from the main menu.
4. On the NewImage tool window, select the following parameters:
- Identifier: RGB
- Sample format: 32-bit floating point
- Color space: RGB color.
- Width, height and channels with their default values: 256, 256 and 3, respectively.
- Initial values: R=0.4, G=0.25, B=0.6
Click the blue circular button to apply globally, or press F6. Now we have a "RGB" image filled with a constant value (a violet color).
5. On the NewImage tool window again, select:
- Identifier: L
- Color space: Grayscale.
- Initial values: K=0.7
Leave the rest of parameters unchanged. Apply globally and you have an "L" grayscale image filled with constant gray value (70% gray).
6. Launch the LRGBCombination tool. Select:
- L = "L"
- R, G and B disabled (unchecked).
Leave the rest of parameters unchanged. Apply this instance to the "RGB" image we have created in step 4 above.
7. Now place the mouse cursor over the RGB image. You should read the following pixel values:
R= 0.77297
G = 0.59561
B = 0.98378
If you read these values, then everything is working correctly. Otherwise, we have a problem and we'll have to work to find it.
Offline dsnay
« Reply #49 on: 2011 January 24 14:55:45 »
Juan,
I followed your steps and ended up with numbers very close to what you expected showing up in the status bar across the bottom of the window. So now we have to figure out where to go from here......
Dave
Offline dsnay
« Reply #50 on: 2011 January 24 15:12:24 »
I told you all I was brain dead at the beginning of this. I just tried the process again, this time remembering to stretch the RGB data and I ended up with a non-black image.
Thanks for all your patience folks! and I'm sorry to have wasted your time.
Dave
Offline Harry page
« Reply #51 on: 2011 January 24 15:19:50 »
Got me confused now as I was sure you stretched the RGB in the last video  ???
Harry
Dave
Harry Page
Offline dsnay
« Reply #52 on: 2011 January 25 03:39:33 »
Harry
Dave
I did, but for some reason it is working now, whereas it didn't before. I wonder if resetting the settings as Juan suggested fixed something.
Dave
« Reply #53 on: 2011 January 25 08:20:36 »
Hi Dave,
Perhaps you had a wrong RGB working space configuration. Anyway, what counts is that it works now. So enjoy it! ;)
