Author Topic: Has this tutorial (integrate narrowband and broadband) been implemented in PI?  (Read 3458 times)
Offline DaveB
http://pixinsight.com/tutorials/narrowband/
This is the second paragraph in the tutorial:
"Since the algorithm can be easily automated, it will be implemented as a PixInsight module as soon as possible."
I was wondering if this has been implemented. I don't think that it is the NBRGBCombination script, but maybe I'm wrong.
Dave
Offline akulapanam
Unfortunately that is correct.  The NBRGBCombination script uses a different method.  I have actually been having great luck using image integration to do a noise weighted integration into both R and L.
Offline mmirot
 "I have actually been having great luck using image integration to do a noise weighted integration into both R and L."
How are you doing this?  Image integration works with minimum of three images. Are you doing this with subs?
Max
Offline RickS
You can add the same two images twice.
