Author Topic: Real-Time Preview 'Flash'  (Read 4617 times)
Offline Warhen
    • Billions and Billions
« on: 2015 December 05 07:00:20 »
I hesitate to report this as a 'bug.' Could be some interaction with my video card, etc. I like to toggle the R-T preview on/off to see a before/after view. When I do that, the R-TP window flashes pure white for a second. As not to ruin my night vision, I have to close my eyes. ;>)
Best always, Warren
Warren A. Keller
www.ip4ap.com
Re: Real-Time Preview 'Flash'
« Reply #1 on: 2015 December 05 09:00:34 »
Hi Warren,
I cannot reproduce this problem on Windows 8.1 and Windows 10. I have no Windows 7 machine at hand now, but I doubt it would be different. Anyway this problem should have been detected in our tests, which are carried out on the three Windows versions.
Offline albireo00
« Reply #2 on: 2015 December 06 09:08:18 »
Hi Juan.
The same problem for me with the new version 1193 on windows 7.
A short white delay toggle on/off real time preview. Larger on wavelets process and very short on histogram or curves.
Offline frant
« Reply #3 on: 2015 December 07 04:07:27 »
Another data-point, I have this too, Windows 7 64-bit, 1193.
I'm not considering it a problem or bug, but it is happening.
Offline Warhen
« Reply #4 on: 2015 December 07 10:41:46 »
Sorry Juan- should have specified it's Windows 10! Interesting that albireo00 and Frant are seeing it too. Thanks!
Best always, Warren
Warren A. Keller
www.ip4ap.com
Offline MikeOates
« Reply #5 on: 2015 December 10 01:19:52 »
I have also a similar white screen issue, but not the same as those already reported.
When I have set a process in motion, i.e. MT the console pops out and the process starts, then part way through the image screen turns white (just the image window), then when the process completes it returns to show the newly processed image.
It's not a problem, I just thought it may be connected.
Using 1193 on Windows 10
Offline Cosmick
« Reply #6 on: 2015 December 10 01:50:13 »
Also happens on my computer. Only seems to happen when I toggle the RTPreview from the process window and usually not the first time I turn it off/on. If I use the toggle in the RTPreview window it does not flash.
Windows 7  and Pixinsight 1.8.4.1193
Clear Skies
Mick
Offline andreasmax
« Reply #7 on: 2015 December 14 10:17:32 »
Same here on Mac OS 10.10.5 at any tools using Real Time Preview:
- Open the Real Time Preview
- Waiting for the initial render of the Preview
- Clicking the small RTPreview Icon at the left of the tool the Preview screen turns white until it has done the calculations.
- Does not turn white when turning the preview on and off at the top left icon inside the preview
Mac OS 10.10.5
PI: PixInsight Core 01.08.04.1193 Ripley (x64)
Andreas
Offline Sean
    • My Personal Website
« Reply #8 on: 2015 December 20 11:24:52 »
Also seeing this on new iMac Retina 5K, Mac OS X 10.11.1, latest Ripley 1195.
Sean
« Reply #9 on: 2015 December 21 02:02:20 »
Unfortunately, currently there is no valid fix for this issue. It is the result of a combination of Qt bugs on Windows and OS X. If I fix this problem, then I create others that are much worse on both platforms. Of course this does not happen on the reference Linux implementation.
Anyway, clicking the Real-Time Preview button on a tool window *is not* the appropriate way to perform before/after comparisons, since this forces recalculation of the whole real-time preview rendition. The correct way is to click the "Show transformed image" button on the Real-Time Preview window. There is no "flash" if you click this button.
This issue has been tagged as a low-priority bug, but it will eventually get fixed in a future version. Sorry for the inconvenience.
Offline niteman1946
« Reply #10 on: 2015 December 21 05:29:23 »
Excellent!
Thanks Juan.
Offline Sean
« Reply #11 on: 2015 December 21 10:12:56 »
Juan,
Thanks for the update, and the info on the difference between the two buttons.
Always learning.....
Sean
