Author Topic: OSX 10.9 Mavericks update  (Read 5253 times)
Offline Andrei Ioda
« on: 2013 October 23 10:18:15 »
After update my OSX to 10.9 i can't open any files. PixInsight close the finder windows after open it.
Offline Josh Lake
Re: OSX 10.9 Mavericks update
« Reply #1 on: 2013 October 23 12:24:37 »
That's odd.
Have you tried the various ways of opening? Cmd-O, File/Open, double click on the background? Do they all close the Finder dialog?
Offline Andrei Ioda
« Reply #2 on: 2013 October 23 12:52:51 »
Cmd-O and File/Open don't work too. I can open file when double click on the file in Finder only.
Offline NGC7789
« Reply #3 on: 2013 October 23 15:10:56 »
I cannot reproduce this on my early 2009 2.93Ghz CoreDuo iMac.
Offline Andrei Ioda
« Reply #4 on: 2013 October 23 23:10:54 »
I have two computers. One iMac (mid 2011) on my work and second MacBookPro with Retina (2012) at home. This issue reproduces on both.
I remind, this issue appeared after update OSX to 10.9. Before, everything worked perfectly.
P.S. When i open BatchPreprocessing and try to open files i get error. (see attached screenshot)
Offline Andrei Ioda
« Reply #5 on: 2013 October 24 23:27:41 »
I've just found solution. PixInsight needs adding in Accessibility.
Offline NGC7789
« Reply #6 on: 2013 October 25 04:43:26 »
That is good news!
I am curious though. I do not have PixInsight in Accessibility and yet have not had your issues. In fact none of my applications are there. Perhaps there is some difference with how I have installed.
Offline Josh Lake
« Reply #7 on: 2013 October 25 09:44:04 »
Interesting find! How do you add PI to this list?
Offline NGC7789
« Reply #8 on: 2013 October 25 10:51:51 »
Found it. You have to drag your application icon to the preference panel to add it to the list. Of course the preference pane must be unlocked first.
Offline Josh Lake
« Reply #9 on: 2013 October 25 10:54:26 »
Ah ha, not from the Dock but straight from the Applications folder. Thanks.
Offline fudgie
« Reply #10 on: 2013 November 02 01:11:36 »
Didn't fix it for me. I added it to the Accessibility preferences pane, but the file open dialog instantly disappears still.
It seems that if I first open a file by dragging it into the workspace, the Open File dialog starts working.
« Reply #11 on: 2013 November 14 11:10:10 »
Hi all,
This is a bug in Qt 4.8.5, which is the version of Qt used in PI 1.8.0 RC7:
https://bugreports.qt-project.org/browse/QTBUG-34012
Fortunately, this bug has been fixed a few days ago. We are very close to a 1.8.0 release version of PixInsight, so I ask for a bit of patience. Hopefully, the new version will be 100% compatible with Mavericks.
In the meanwhile, the workaround is using platform-independent file dialogs:
Edit > Global Preferences > File I/O Settings > Use native file dialogs (uncheck, then press F6 to apply globally).
Of course, PixInsight should not be added to Accessibility...
Sorry for the inconvenience.
