Author Topic: Sadr Region 9 panel mosaic  (Read 5239 times)
Offline jmtanous
« on: 2011 September 27 14:50:11 »
I started this project a mouth ago or so, and yesterday I finally manage to process the last panels. I used the new GradientMergeMosaic to stitch the panels. It worked great.
This is  a 9 panel mosaic. The lights were captured with a mini borg 60mm @ 3.8 with a Baader Ha filter and a QHY9M.
The total number of frames is 64 x 20min or 21h20m.
This is what I did:
-- Calibrate each panel
-- DBE each panel
-- Create 3 super panels using GradientMergeMosaic
-- Crop each super panel (DynamicCrop)
-- Stitch the 3 super panels using GradientMergeMosaic
-- Crop the final panel (DynamicCrop)
-- Histogram adjustment (HistogramTool)
-- HDRWaveletTransform layer 7, 3 iterations
-- Soft Star reduction using a starmask an morphological transform
-- Noise reduction using ATrousWaveletTransform on 1st layer 1 iteration
Link to high res image:
http://tinyurl.com/663enjw
Jose
Offline Lex
  • We do it at night...
Re: Sadr Region 9 panel mosaic
« Reply #1 on: 2011 September 28 14:33:20 »
really nice detail, it's kindely crowded in that region :-)
Great shot!
What mount are you using?
Best
Lex
Clear Skies!!
Lex
Offline jmtanous
« Reply #2 on: 2011 September 28 14:48:08 »
Hi Lex,
Thanks for your comments.
I use a Vixen SXD mount.
Jose
Offline Lex
« Reply #3 on: 2011 September 29 13:19:27 »
Thanks and again; really nice Shot!!!
Best
Lex
Clear Skies!!
Lex
Offline Jules
« Reply #4 on: 2011 September 30 09:54:25 »
Jose
A super image.
Regards
Julian
« Reply #5 on: 2011 September 30 13:29:01 »
this is wonderful. i've been dreaming of doing something like this for a long time but i'm not sure i'll ever accomplish it :)
Offline jmtanous
« Reply #6 on: 2011 September 30 13:53:36 »
Jose
A super image.
Regards
Julian
Thanks Julian!
Jose
Offline jmtanous
« Reply #7 on: 2011 September 30 13:56:06 »
Thanks pfile!
Is not hard to do it. Why you don't give it a try? A 1x2 panels mosaic or 2x2 is easy to achieve and the processing is very forgiving (ones you properly flatten the panels)
Jose
« Reply #8 on: 2011 September 30 15:17:31 »
being crazy, i wanted to do this with a 200mm lens == hella frames...
Offline jmtanous
« Reply #9 on: 2011 September 30 15:24:48 »
The focal length of my miniborg is 230mm.
The main problems with wide fields mosaics are:
-- Gradients
-- Panel rotations. The closer to the celestial poles the worst it gets.
Jose
Offline roberto_volpi
    • IL MIO SPAZIO
« Reply #10 on: 2011 October 01 00:52:40 »
Wow, 9 panel
Congratulations, great image
Roberto
« Reply #11 on: 2011 October 01 03:13:36 »
... I used the new GradientMergeMosaic to stitch the panels. It worked great....
I love to hear that  :)
Offline jmtanous
« Reply #12 on: 2011 October 02 16:15:28 »
Wow, 9 panel
Roberto
Thanks Roberto!
Jose
Offline jmtanous
« Reply #13 on: 2011 October 02 16:19:23 »
Georg,
Thanks for the tool. It worked great.
One issue that I found (and you are already aware of it) it that the tool creates some artifacts when stitching linear data. To workaround this I had to stretch a little bit the panels before feeding them to your tool.
Jose
