Author Topic: Installed the WBPP update but script isn't in the menu  (Read 1713 times)
Offline ac4lt
« on: 2019 November 19 16:26:32 »
I did the update today to pick up the WBPP script and it says it completed normally. I restarted PI and the updates were applied. But, it's not in the batch processing menu on the scripts menu or anywhere else.
If I go to resources / updates / view installed updates, I see this in there:
Package type : Script
Title        : WeightedBatchPreprocessing script version 1.4.1 (update)
Repository   : https://pixinsight.com/update/1.8.8-1/
File name    : 20191119-1-script.zip
Release date : 2019-11-19 00:00:00
Install date : 2019-11-19 20:25:43
So, PI thinks it's installed. I also see it in /Applications/Pixinsight/src/scripts/WeightedBatchPreprocessing on the fijesysstem.
Any ideas of what I need to do to get it to show up?
Thanks!
Offline robyx
Re: Installed the WBPP update but script isn't in the menu
« Reply #1 on: 2019 November 20 05:16:38 »
you should find it under Scripts->Batch Processing->WeightedBatchPreprocessing.
Robyx
Offline ac4lt
« Reply #2 on: 2019 November 20 05:18:00 »
That’s where I expected to see it. But, it isn’t there.
Offline robyx
« Reply #3 on: 2019 November 20 05:19:46 »
If you open the Script -> Feature scripts do you see it in the list?
Offline ac4lt
« Reply #4 on: 2019 November 20 07:20:44 »
No, it isn’t there. Can I just do an “add” from there and point it at he the directory in the installation where the script is living?
Offline robyx
« Reply #5 on: 2019 November 20 07:22:30 »
maybe it should be a workaround, unless it will try to copy the files over themselves which will raise an error I guess
Offline ac4lt
« Reply #6 on: 2019 November 20 07:35:49 »
I gave that a try and it seemed to work. The script is in the menu now. Hopefully this was a one time fluke and not a problem that will recur on each update.
Offline robyx
« Reply #7 on: 2019 November 20 07:39:24 »
happy to hear that!! :)
