Author Topic: PhotometricColorCalibration wont work  (Read 2022 times)
Offline blinky
« on: 2018 January 23 13:24:32 »
I get the error below when I run the Photometric Colour Calibration routine - Have checked the RA/Dec and pixel size/focal length are correct, not sure what else to do?
Processing image C:/Users/Craig/AppData/Local/Temp/PCC_T_8VL7YQJLJV3U.xisf
Reading image:
Loading image: w=3040 h=2016 n=3 RGB UInt16
88 FITS keyword(s) extracted.
Seed parameters for plate solving:
   Image coordinates: RA=05 35 33.800, Dec=-05 16 12.40
   Resolution: 0
Starting StarAlignment iteration
Catalog Bright Stars already loaded
Catalog Bright Stars size: 9046 objects
*** Error: Unable to solve the image: Error: Invalid matrix inversion: Singular matrix.
** Warning: Process finished with errors:
  PCC_T_8VL7YQJLJV3U.xisf: The image could not be solved
*** Error: Failure to plate solve image: light_BINNING_1_integration
Reading swap files...
610.707 MiB/s
<* failed *>
Re: PhotometricColorCalibration wont work
« Reply #1 on: 2018 January 23 13:57:25 »
can you post the xisf so someone can take a look? google drive, dropbox... post link here
Offline blinky
« Reply #2 on: 2018 January 23 14:43:48 »
Here you go...  https://www.dropbox.com/s/f4aw6pt5sybwaa8/light_BINNING_1_integration_DBE.xisf?dl=0
I grab the co-ords from the image but manually enter 800mm focal length and 7.8 microns for my QHY8 pixel size
« Reply #3 on: 2018 January 23 15:37:29 »
The file would not work as you stated. I decided to resave the file without the FITs header keywords. I then opened that image and using the default settings the image solved. Something in the keywords is wrong or corrupted.
Offline Andres.Pozo
« Reply #4 on: 2018 January 24 02:18:31 »
The problem is that the key FOCALLEN has a 0 value. ImageSolver ignores it but PCC doesn't. I can not fix this since PCC was not written by me.
After clicking "Acquire from image" in PCC you can manually set the focal length and pixel size to the correct values. Another workaround would be to first solve the image using ImageSolver and then apply PCC. In any case I would recommend to always use this method since it lets you try PCC with different parameters without needing to solve the image again.
Also, for this image I would activate the distortion correction in ImageSolver. There is a noticeable geometric distortion at the corners. The solution using distortion correction has a RMS error of only 0.61 pixels versus 2.4 without it.
Offline blinky
« Reply #5 on: 2018 January 27 11:31:08 »
Odd - I entered the values that are on the screenshot and it still wont solve it!
« Reply #6 on: 2018 January 27 14:47:25 »
You still have the resolution = 0 issue with the file. I saved the image without the keywords and than solved that saved image. Andres method is easier. You click on the "Acquired from Image" button and then manually enter your Pixel Size and Focal Length.
Offline blinky
« Reply #7 on: 2018 January 28 02:29:12 »
I thought I did Andres method - I you look at the screenshot you will see I have the same focal length as Andres screenshot.  Where is the resolution field? I dont see anything set to 0
« Reply #8 on: 2018 January 28 09:27:35 »
The resolution is not a setting. It is parameter showing Process Console window. Try these parameters, 'Force late solving' and 'Ignore existing metadata'.
Offline blinky
« Reply #9 on: 2018 February 06 14:29:55 »
Tried that on an image tonight -  same problem, even if I select force plate solve and ignore existing metdata
Offline blinky
« Reply #10 on: 2018 February 06 14:44:22 »
Finally figured it out -  you cant drag the little triangle to execute, you need to click the square!
« Reply #11 on: 2018 February 06 15:06:51 »
« Reply #12 on: 2018 February 07 00:40:25 »
Weird. If you drag the triangle on the active image view, both triangle and square icons perform exactly the same task. I guess it's something else...
