Author Topic: How do I close the documentation?  (Read 4660 times)
Offline michael1026
« on: 2016 May 30 17:53:15 »
screenshot: https://i.gyazo.com/a6dee1219203a52fec51c388995d47aa.png
It causes the program to lag quite a bit and I can't get it to close.
Re: How do I close the documentation?
« Reply #1 on: 2016 May 30 18:14:29 »
The two little arrows at the botton, near the heart
Offline michael1026
« Reply #2 on: 2016 May 30 20:34:24 »
Thank you for the reply, but I don't see two arrows or a heart towards the bottom...
Offline jshortt
« Reply #3 on: 2016 May 30 21:10:03 »
I think the "Hide Extension" button (it's two small arrows pointing to the left) that's at the bottom of the Process Explorer to the right of the label "Process XX of YY" is what you're looking for
John
Offline michael1026
« Reply #4 on: 2016 May 31 14:16:59 »
John
Thank you. Apparently there's a bug because that's not shown on my screen. I believe it's under the task bar, and I can't make the window any smaller. What I showed in the screenshot is all that's visible to me.
« Reply #5 on: 2016 May 31 14:36:06 »
Hi Michael, it is strange. Please close File Explorer (x in the top right of the image you have attached) and show us how PI looks like in a full desktop screenshot.
Which is the resolution of you monitor?
Saludos, Alejandro.
Offline michael1026
« Reply #6 on: 2016 June 01 12:32:42 »
Saludos, Alejandro.
Screenshot: https://i.gyazo.com/5cfe38b17acefb1d3b8eba99bef8c2de.png
My monitor resolution is 1366x768
« Reply #7 on: 2016 June 01 14:14:11 »
Hi, now it is clear, the PI windows was resized. See here how to put it back to normal.
Saludos, Alejandro.
Offline michael1026
« Reply #8 on: 2016 June 01 15:55:47 »
Saludos, Alejandro.
Thank you. It let me drag the window, but wouldn't let me resize it. Thankfully, when I moved the window, then expanded the window, it showed everything. Thanks!
Edit: Odd, sometimes it'll still go back to the state I showed in the original screenshot. If I figure out what's causing that, I'll edit this again.
« Reply #9 on: 2016 June 01 16:02:39 »
you should be able to resize it..., See also this video because with your resolution you may need to close or relocate some Explorer or Toolbar.
I will disable the previous video, let me know if you need it again.
Saludos, Alejandro.
« Reply #10 on: 2016 June 01 16:03:50 »
That is because it need to be resized
« Reply #11 on: 2016 June 01 19:58:40 »
One thing to know is your display(1366x768) is below the minimum required resolution and the minimum reasonable resolution as from the system requirements page on the main PI website.
In the Global preferences settings you might want to try setting the 'Maximize at startup' or 'Full screen at startup' also.
« Reply #12 on: 2016 June 02 00:29:05 »
Nothing to add to Alejandro's and Mike's comments. You'll have to close explorer windows and tool bars, but even doing that, 1366x768 is too low of a screen resolution for PixInsight.
Offline jolasa
« Reply #13 on: 2016 June 04 11:42:39 »
What is the minimum resolution for PI?
JonS
