Author Topic: Processing Sequence  (Read 3182 times)
Offline John_Gill
Processing Sequence
« on: 2016 May 12 01:01:03 »
Is there a preferred sequence to processing an image?
Regards
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline bmhjr
Re: Processing Sequence
« Reply #1 on: 2016 May 12 07:15:24 »
I am still learning, but I had the same questions when starting and still come across steps I am unsure about.  Others can chime in.  Every image is different and will present it's own set of steps required.
I try to break down the sequence to Linear and Non Linear.  After proper calibration and integration your image is linear and the data is unchanged.  Here is what I do for DSLR images
Linear:
Linear Fit
Background Nuetralization
Color Calibration
Deconvolution
HSV Repair
Mild noise reduction with TGVDenoise and MMT
Mild color saturation
Mild star reduction
Once I am happy with the general appearance and the image is cleaned up and calibrated, I will stretch it to Non-Linear
Non-Linear:
Masked Stretch or Histogram Stretch
Set proper Black Point with HT
Additional Color Saturation
Additional Star Reduction if needed
Final noise reduction
Curves Transformation or LHE to increase contrast
This is my general workflow and would be happy on any comments or additional steps required.  Hope that helps
Bill
Offline John_Gill
« Reply #2 on: 2016 May 12 08:26:05 »
Thanks for the heads up!  I will add it to my list of processing sequence.
Regards
John
Offline bmhjr
« Reply #3 on: 2016 May 12 08:46:26 »
Ha, I left out gradient remove with ABE or DBE. Dynamic crop the stacking artifacts then I do ABE/DBE right after linear fit before background neutralization and color calibration.  There are a lot of steps  :surprised:
Offline DaveB
« Reply #4 on: 2016 May 14 12:37:19 »
I'm just learning but I used this as a starting point:
http://harrysastroshed.com/workflow.html
Offline llpastro
    • Sonoran Dark Skies
« Reply #5 on: 2016 May 15 07:58:24 »
Bill what process do you use for mild star reduction?
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline bmhjr
« Reply #6 on: 2016 May 15 10:23:15 »
Larry,
I have been following this example and it works very well.
http://www.deepskycolors.com/archive/2011/09/08/star-size-reduction-via-Morphological-.html
Bill
Offline llpastro
« Reply #7 on: 2016 May 16 06:41:09 »
Thanks.
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
