Author Topic: Solar Noise Reduction  (Read 2183 times)
Offline Scooot
« on: 2016 May 10 04:34:08 »
I took my first solar image with my scope of the Transit yesterday, just a single frame.
I used the MultiscaleLinearTransformation for noise reduction on the background, with the linear mask inverted by the process, before I stretched it. Would it be normal to apply it to the solar disk itself as well, with the background masked, perhaps to a lessor degree. If so can anyone suggest some settings.
Many thanks for any advice.
Richard
Re: Solar Noise Reduction
« Reply #1 on: 2016 May 11 01:13:38 »
That would be perfectly acceptable in this case IMO. You can use any intensity transformation to build the mask, as HistogramTransformation or CurvesTransformation. But RangeSelection (MaskGeneration category) will probably be easier.
Offline Scooot
« Reply #2 on: 2016 May 11 04:44:07 »
Thank you juan,
The inverted mask that the MultiscaLinearTransformation produced worked quite well when I applied the process to just the background. I did this because when I stretched the image without any noise reduction the background looked awful. However by applying noise reduction to the background only seems to have created a passable image, in my eyes anyway, considering it was a single frame. So I was just wondering whether noise recuction on the disk would help much more and whether it would be normal to do this when processing solar images. Have to just try it I suppose.
Richard
