Author Topic: PI chrashes when open Fujifilm RAW File  (Read 2994 times)
Offline habach
« on: 2016 May 03 03:34:49 »
PI 1.08.04.1195
Mac OSX 10.11
Since I updated the Firmware of my Fujifilm X-E2 to Version 4.0, PI chrases when I open a raw file.
Fujifilm made some improvements (compression) in his raw files, this problem occurs also with raw files from the new X-Pro2 and X-E2s.
Is it possible to implement such a bugfix like in Rawtherapie that also use dcraw code. Or is a new dcraw version on the way?
I found this infomation on github about - Segfault opening Fujifilm X-E2 firmware v4.0 RAF files
https://github.com/Beep6581/RawTherapee/issues/3137
P.S, here's the full email from Dave:
I haven't figured out Fuji's 0xc000 tag.  In the older file
it's (using my parse.c program):
Fuji tag=0xc000, len=21984, data = 00 00 4f 02 48 13 00 00 e0 0c 00 00 ...
     0x00001348 is the width (4936 decimal) and 0x00000ce0 is
the height (3296), in little-endian byte order.  With the new
firmware it looks like:
Fuji tag=0xc000, len=21984, data = 00 00 56 03 57 52 54 53 48 13 00 00 e0 0c 00 00
     The extra four bytes "57 52 54 53" spell out the letters
"WRTS".  Not sure what that stands for.  I also see WRNEDCTS,
DSCF, DCNETSTS, TSNERDTS, RDNESQTS, SQNERSTS, RSNECPTS, and
CPNEVFTSVFNE, none of which appear with the old firmware.
     Anyway, this patch finds the width and height until the
next firmware update:
--- dcraw.c     2015/05/25 02:29:14     1.476
+++ dcraw.c     2016/02/10 21:28:34
@@ -6721,7 +6721,7 @@
     } else if (tag == 0xc000) {
       c = order;
       order = 0x4949;
-      if ((tag = get4()) > 10000) tag = get4();
+      while ((tag = get4()) > 10000);
       width = tag;
       height = get4();
       order = c;
Hannes Bachleitner
Re: PI chrashes when open Fujifilm RAW File
« Reply #1 on: 2016 May 03 04:57:11 »
Hi Hannes,
I have just released an update that fixes this problem. Thank you so much for the heads up, and for all the information you have provided. It has been of great help to solve this issue quickly.
Offline habach
« Reply #2 on: 2016 May 03 05:16:39 »
Hi Juan
Wow, you are realy fast :)
Thanks a lot
Hannes
Offline habach
« Reply #3 on: 2016 May 03 05:26:11 »
Hi Juan
I installed the fix now, works perfect!
Hannes
