Author Topic: Adaptive Stretch chart  (Read 2139 times)
Offline Scooot
« on: 2016 April 17 09:34:16 »
Probably very simple, but on the adaptive stretch chart, bottom left I think, there's a small menu that allows you to change the size of the chart. I've played around with this and now the chart fills my screen, but I can't view the menu at the bottom to change it back again. I drag it as high as I can but its not enough. Can anyone tell me how to resize it to the original size. The adaptive stretch rest button doesn't affect it.
Richard
Offline oldwexi
    • Astronomy Pages G.W.
Re: Adaptive Stretch chart
« Reply #1 on: 2016 April 17 11:04:14 »
Activate the "AdaptiveStretch Curve Graph" window,
Enter the number 4, or 6, or 8 and you will resize the CurveGraph window  OR
Use F4.
this should bring up a  gray slideup window at the bottom of the screen to change size.
And better, get a new display with higher resolution as HDMI because HDMI is for videos and not
sufficient for photo-image processing.
Gerald
« Last Edit: 2016 April 17 11:10:29 by oldwexi »
Offline Scooot
« Reply #2 on: 2016 April 17 13:30:55 »
Brilliant, thank you Gerald, I knew it would be simple to those he know. :)
Richard
