Author Topic: Can no longer adjust screen size  (Read 2636 times)
Offline LarryC
« on: 2016 April 09 13:11:47 »
No other program are affected, reboots do not help.  I can no longer adjust the vertical size of the overall workspace.  This is a problem in that the program always opens too large vertically for my screen so I routinely shrink it from the upper right, re-position, then enlarge from the lower right to fit properly - an old annoyance, but never a problem until recently.
The change occurred "around" the time of the recent updates to...I think, PSF?
Offline niteman1946
Re: Can no longer adjust screen size
« Reply #1 on: 2016 April 10 10:01:34 »
Hi Larry,
See my comments at the bottom of this thread.
http://pixinsight.com/forum/index.php?topic=9480.0
Hope it helps.
Mark
Offline LarryC
« Reply #2 on: 2016 April 10 16:16:14 »
Mark,  This is a different problem, though I have that one too and will try your fix (thanks).
The new problem appears to be a bug, not a settings issue.   The PI window can no longer be reduced in size vertically.  Even with the cursor at an angle in the upper right )or lower left, etc.) it will only resize horizontally.
« Reply #3 on: 2016 April 10 20:53:42 »
Hi Larry, this may help.
Saludos, Alejandro
