Hi Miska!
I would not waste exposure time with exposing and stacking multiple exposures in the field.
It is a matter of planning before you go outside.
The simplest way to find the center of the "invisible" object is to make a short exposure
for example 10 seconds after you have placed the scope relatively near to your target.
In this exposure only the brighter stars are visible. They show, especially with Simeis_147,
nice significant brighter star combinations.
Running PI Star Generator with the center of Simeis_147/Sh2-240
creates this significant star combinations also. Comparing the stars in the exposure and
the stars created in PI-starfield gets you very fast to the Point where you want to expose.
No Need to see your object.
Find attached a link to a screenshot which shows
the created starfield around Simeis_147, the process with the Parameter and
a planetariumsshot which also shows Simeis147 and its significant stars.
![](http://www.werbeagentur.org/oldwexi/Planning_invisible_objects.jpg)
I personally have moved away from imaging bright objects, i moved to Imaging molecular clouds and
dark nebula which are not visible also on a longer single shot.
So, the method to find the significant star combinations is a must for me to get the scope fast to
the needed point. Stacking is a NoGo for me.
Hope thats an idea for you.
Gerald
