Author Topic: API error Star alignment  (Read 3593 times)
Offline astroman2
« on: 2016 March 06 23:12:27 »
Hi Team,
I get the following error when doing star alignment with the working mode set to Putative Star matches.  Version 1195. Can anyone help?
StarAlignment: Processing view: m42_7_300s_int_ABE_bg_cc_DBE
Loading reference image:
F:/m42_1/merge3/30sec/CatalogStars_crop.xisf
Loading image: w=12113 h=5876 n=1 Gray Float32
F:/m42_1/merge3/30sec/CatalogStars_crop.xisf:
Noise reduction: done
Structure map: done
Detecting stars: done
596 stars found.
m42_7_300s_int_ABE_bg_cc_DBE:
Structure map: done
537 stars found.
* Distortion correction: Iteration 1 of 20
Matching stars: done
182 putative star pair matches.
*** PixInsight API Error: CreateImageWindow(): Low-level API function error
API error code = 64:
Invalid sample format
<* failed *>
Regards
Scott
Re: API error Star alignment
« Reply #1 on: 2016 March 11 01:03:20 »
This cannot be reproduced on any platform. I would need to have the images (reference and target) to say something more. As always, without the images we have no way to help.
Offline astroman2
« Reply #2 on: 2016 March 13 21:55:54 »
Juan,
Attached is link to two files (sorry 450MB) with which this error occurs.
https://www.dropbox.com/s/ne7glfdzn3qwjlm/CatalogStars_crop.xisf?dl=0
https://www.dropbox.com/s/hj2nf85wqfzwnu7/m42_7_300s_int_ABE_bg_cc_DBE.xisf?dl=0
Error only occurs when reference image is to a "file".  Works ok with reference image to  a "view".  Platform is Windows 7.
See details below:
Structure map: done
848 stars found.
Structure map: done
589 stars found.
235 putative star pair matches.
<* failed *>
CatalogStars_crop:
Structure map: done
848 stars found.
Structure map: done
589 stars found.
Blending grayscale bitmap: done
Blending bitmap: done
15.279 s
Regards
Scott
« Reply #3 on: 2016 March 13 23:09:48 »
Scott
I tried with the default settings in Star Alignment but that didn't work. My next step was to use very aggressive settings and that did. I would not normally use anything near these settings but I just wanted to show that StarAlignment would work.
« Reply #4 on: 2016 March 13 23:21:45 »
Scott
I just saw where your error occurs when using the reference image from a file. I ran the StarAlignment again with the catalog star file from the hard drive and not as a view. I had no problem. I am also running Windows 7 and the latest PI.
Offline astroman2
« Reply #5 on: 2016 March 15 14:09:57 »
Mike,
Thanks for the info. I eventually solved it too. It was during the hunt for a solution and only whilst using the "putative star matching' working mode that I got the error.
Regards
Scott
