Author Topic: CosmeticCorrection doesn't work (Windows 10 x64; Ripley ... 1195)  (Read 3460 times)
Offline Astrodoc
    • AstroDoc - Astrophotography by Ron Brecher
The real time preview shows CosmeticCorrection parameters are set properly to remove a bad column, but when I apply it to the file, the bad column is not removed, or even affected.  Noise Evaluation Script shows that before/after images are identical in terms of noise, so it appears CC is not being applied.
Clear skies,
Ron
Re: CosmeticCorrection doesn't work (Windows 10 x64; Ripley ... 1195)
« Reply #1 on: 2016 February 20 07:57:23 »
Hi, I can reproduce it on Lunix 1.8.4.1197. Only "Use Defect list" the rest works fine.
Saludos, Alejandro.
Offline NKV
« Reply #2 on: 2016 February 22 19:44:22 »
I can't reproduce the problem.
Please show PrintScreen with CC settings and console output.
Offline Astrodoc
« Reply #3 on: 2016 February 23 15:45:23 »
The problem occurs only with the Use Defect List portion.  Output looks normal, like yours.  If you preview it, it shows bad columns being removed, but when it is run, the bad columns remain in the generated file.
Clear skies,
Ron
« Reply #4 on: 2016 February 23 16:40:32 »
Well, I tried again and fail to reproduce it. Different images and format and it worked fine this time. I don't know...
Offline NKV
« Reply #5 on: 2016 February 23 18:22:02 »
So many words...
Just show me the console log and CC settings(picture PrintScreen).
Offline Astrodoc
« Reply #6 on: 2016 February 24 07:02:43 »
It is now working as usual.  Three tries on FIT and XISF files, including the same file that originally had the problem, and now it works normally.
I do not understand, since nothing changed (except I have rebooted computer a few times since originally reporting the issue).  Both I and Alejandro observed the same issue with Use Defect List, and then it worked normally for both of us.
I didn't attach any screen shots since everything is working fine.
Thanks to all for your help.  I will post here again if the issue occurs again.
Clear skies,
Ron
