Author Topic: MureDenosie info in header after intergration  (Read 3352 times)
Offline mmirot
« on: 2015 December 18 13:59:23 »
MureDenoise
" The variance scale parameter can also be set based on information from an ImageIntegration process log file. The log file is a manually created .txt file containing a copy of the Process Console log generated by ImageIntegration.  "
It would be nice to have the variance scale parameter added automatically into the integrated image. It could then be used by the MureDenoise script.
(You could build MureDenoise in image integration  as a check box option too)
Max
