Author Topic: Print from PixInsight  (Read 5515 times)
Offline Geoff
« on: 2015 December 17 03:09:10 »
I would like to print from within PixInsight. This capability has been long promised, but is still not here. I really dislike having to fire up the other application just to print a file.
Geoff
Don't panic! (Douglas Adams)
Re: Print from PixInsight
« Reply #1 on: 2015 December 17 03:27:59 »
Hi Geoff,
Actually, PixInsight includes a complete printing system. It is enabled by default on FreeBSD and Linux, but disabled by default on OS X and Windows. You can enable it by running the PixInsight core application with the "--with-printer" command-line argument (without quotes). This will enable the printing menu commands, namely FILE > Printer Setup, FILE > Printer Color Management,  and FILE > Print.
Printing is now disabled by default on OS X and Windows because I want to improve it significantly to make use of native printer features on these platforms, especially on OS X. One of the areas where we need more improvements is color management when printing directly to physical printer devices.
So you can indeed print from PixInsight, including generation of PDF documents. Our printing system makes use of the advanced pixel interpolation algorithms and accurate color management transformations implemented on the PixInsight platform.
Offline Geoff
« Reply #2 on: 2015 December 17 22:04:21 »
Hi Juan.  Not sure what I'm doing wrong.  Do I simply type --with-printer as a command line or is there more to it.  I get a response "Command not found.
Geoff
« Reply #3 on: 2015 December 17 22:26:20 »
Geoff
In Windows I just add the argument to the command line in the Pixinsight short cut itself.
Offline Geoff
« Reply #4 on: 2015 December 17 22:52:27 »
Thanks Mike.  I think that is what Juan meant.  However there is still a problem.  I'm using Win10.
« Reply #5 on: 2015 December 18 02:09:01 »
Geoff
Try a space between the quote" and -. If anything is wrong in the format structure of the argument the error you have will be displayed.
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #6 on: 2015 December 18 08:53:05 »
Juan,
Having moved from Windows to Linux, I was not aware that print was enabled as a default.  But in checking it out yesterday I ran into a problem.  I use an HP7610 printer so that I can print as large as A3+ (19in x 13in).  However when I go into the properties window in PixInsight, it will not allow me to selection anything other that A4 paper.  Am I missing something?
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline Geoff
« Reply #7 on: 2015 December 18 13:55:49 »
Finally got it sorted out. Thanks Mike and Juan.
Geoff
Offline llpastro
    • Sonoran Dark Skies
« Reply #8 on: 2015 December 21 06:30:32 »
Why is it not enabled by default in all versions?
Larry
AP 140 Refractor
SBIG ST-10XME
AP Mach 1 Mount
ATS Portable Pier
Tucson, Arizona
Offline Geoff
« Reply #9 on: 2015 December 21 12:28:27 »
Larry
It is now with the latest version.
