Hi ,
I have just started using the latest Pixinsight version( 1.8 ) on my iMac - Mac details at end of attachment. No problems initially then I got the attached error when saving a processed image. Last process was HDMR.
Possibly related is that the original target is on a USB drive attached to another box running Ubuntu. I had rebooted the Ubuntu system to complete some update installations. The mac did not re-connect which gave a save error message. I reconnected then saved again. I then got the attached error.
The file would appear to have saved correctly.
Error is detected with 'Use native file dialogs' selected and not selected.
I also saved to a local disk with the same error, again the file did save correctly
I shall do the windows thing - shut down and start again to see if it clears.
FYI I have just saved the project with no problem.
Thanks Rob
FYI re-boot and save again no problem.
