Author Topic: CR2 Canon Raw Problems  (Read 2987 times)
Offline jolasa
« on: 2015 December 09 15:57:17 »
Script > Batch Processing > Batch Pre-Processing.
Loaded a bunch of Canon Raw CR2 files: light, dark, flat, bias, selected a ref image and download dir , hit Run.
Progress in main window, see error:  "cannot process Canon Raw files", but it process keeps running.
What's up here?
JonS
Offline NGC7789
Re: CR2 Canon Raw Problems
« Reply #1 on: 2015 December 09 17:36:19 »
What camera are your raw files from?
Can you batch convert your files to .fit or .xisf format?
Offline jolasa
« Reply #2 on: 2015 December 09 18:27:45 »
Camera is Canon 6D, full frame.
File extension is*.CR2.
JonS
Offline jolasa
« Reply #3 on: 2015 December 09 18:39:12 »
To convert Raw to FITS, I think I have to use this:
Select Script > Utilities > BatchFormatConversion
But, in version PI 1.8.4 that I have, BatchFormatConversion is NOT there.
JonS
« Reply #4 on: 2015 December 12 10:31:26 »
Hi JonS, does the script finish? Check the masters to see if you obtain your master dark, master flat, master bias and master light and if they are ok.
when you read "cannot process Canon Raw files", which images is BPP working with? May be you should inspect those individual files and see if there is something strange.
Saludos, Alejandro.
