Author Topic: Hollow saturation cores?  (Read 2676 times)
Offline dmcclain
« on: 2015 November 23 07:39:38 »
I think my remedy will be to use HDR processing in the future. But deep integration images in bright star fields often leads to saturated bright star images, and I expect that. But the cores of these over exposed stars appear to be somewhat hollow. 3-D plots of them show a strong dip in the central region.
What would be the cause of that? I would have thought the images would be solid saturation level.
- DM
Re: Hollow saturation cores?
« Reply #1 on: 2015 November 23 09:12:21 »
is this with no processing whatsoever? some processes (like HDRMultiscaleTransform) can do this when presented with saturated data...
Offline dmcclain
« Reply #2 on: 2015 November 23 11:55:21 »
Yes, it is after some processing. I think I'm beginning to see the conditions under which it happens. A good example of the kind of field where it occurs is the Pleiades region, where with a camera relatively insensitive to blue, you have to expose for very long durations to pick up the reflection nebulae, and the stars burn in quite strongly.
I did a HDR composition and notice that after processing, it too shows subtle amounts of this coring effect. I think it is related to the fact that PI never touches saturation levels in its processing - a sort of DSP-like saturating arithmetic. Seems a reasonable choice, but the result is that some very near saturation levels get affected by things like background uniformizing, while the perimeter of the star with hard saturation never gets affected.
FWIW, in the case of the Pleiades, the HDR results look only very slightly better than normal image integration. All the dynamic range is eaten up by those bright stars, and they are among the less important aspects of the image.
I just checked the deBayered calibrated images, and they show some signs of the coring about to happen. It seems that with saturating arithmetic, it will be nearly impossible to avoid this situation, as it happens in the initial image calibration, and then grows worse with additional processing.
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #3 on: 2015 December 01 12:03:39 »
Did you try shooting two different time iterations, one top bring out the nebulosity and a shorter one to balance the star saturation?  You can then combine them with HDRCombination and get nice results.  This technique is critical in certain areas, the core of M42 being the most obvious, but it would apply here as well.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
