Hi all,
I could use some help. I'm having some problems getting my frames to calibrate. 17 of 35 frames finished calibration with some bias signal still in them. The 35 frames were taken over a few months. The 17 that did not calibrate correctly were taken all on the same night. Other frames were also taken on that night and calibrated OK.
I don't see any issues in Process Console; no warnings or failures, reasonable dark scaling factors, etc. But when I look at the calibrated frames the left edge clearly still has some glow.
Here is a frame that did not calibrate:
Raw: <http://www.kor-astro.net/calibration_issue/Light_G_0030.fit>
Calibrated: <http://www.kor-astro.net/calibration_issue/C_Panel-1_Light_G_0030.fit>
Here is one that calibrated OK:
Raw: <http://www.kor-astro.net/calibration_issue/Light_G_0031.fit>
Calibrated: <http://www.kor-astro.net/calibration_issue/C_Panel-1_Light_G_0031.fit>
Here are the master bias, dark, and flat.
<http://www.kor-astro.net/calibration_issue/Master-BIAS_-20C.fit>
<http://www.kor-astro.net/calibration_issue/Master-DARK_-20C.fit>
<http://www.kor-astro.net/calibration_issue/Master-Flat-G.fit>
The light frames are 120 secs.
The Master Dark is 50x600 second subs.
The BIAS is 200 subs
The flat is 25 subs of about 1.5 seconds.
The camera is QSI683wsg with filter wheel.
The frames that did not calibrate are green.
I know there are some calibration issues with some of the QSI683 cameras--I don't think mine matches the banding that they were seeing, but I will also send QSI a question. So, can anyone give me some pointers? Does it look like a camera issue or do I just not know as much about PixInsight as I thought I did?
Thanks - Shane
