Author Topic: Ubuntu and Windows dual boot help  (Read 2296 times)
Offline mmirot
« on: 2015 September 30 15:00:23 »
I have Ubuntu and Window installed. Both OS are installed on my Primary SSD hard drive.
I am trying to get both OS to load from one BIOS hard drive setting.
Ubuntu boots successfully by selecting Standard Hard Drive 1st in the BIOS  boot order.
If I change the BIOS boot order to to EFI Hard Drive - Windows Boot Manager , windows starts .
I was able to use EasyBCD in Window to create a Ubuntu boot entry in Windows boot Manger.
However, it does not start Ubuntu when selected during Boot (EFI Hard Drive - Windows Boot Manager in BIOS) .
I tried adding the Windows 10 using the GRUB customizer in Ubuntu.
I managed to get a Windows 10 entry appear when Ubuntu boots from the Standard Hard drive but Windows does not load either.
Suggestion?
Max
Max
Offline NGC7789
Re: Ubuntu and Windows dual boot help
« Reply #1 on: 2015 September 30 15:54:19 »
did you follow instructions as here:
https://help.ubuntu.com/community/WindowsDualBoot
They key is to install Ubuntu after Windows.
Offline avarakin
« Reply #2 on: 2015 September 30 20:47:25 »
I always dual boot using grub, although I never tried windows 10
Alex
Offline mmirot
« Reply #3 on: 2015 October 01 07:17:47 »
Found the problem
You have to have both systems installed under EFI or legacy respectively .
I turned off legacy HD in the BIOS and reinstalled PI under EFI.
Bingo I can boot to both OS without switching the BIOS.
