What happens if you disable the Color Management in PixInsight?
Opps! The color cast disapears and the view is matching the one in photoshop. It looks right.
In my previous reply I've explained what actually is happening. If your image has the AdobeRGB(1998) profile embedded, you MUST have color management enabled in PixInsight, Photoshop, and any other application capable of color management.
In PixInsight 1.0.0, the problem is the bug you've detected. Having fixed this bug, in release 1.0.1 hopefully color management will be 100% consistent with PS.
Wich are your working parameters in PI's Color Management? Is the monitor's profile correct?
This looks somewhat odd: In the "Color Management Setup" menu, the Monito Prifile displays as:
Colorific Relative: Philips 107B Gamma: 1.0 Temp: 9300
Which is my monitor but I'm not sure if this is the calibrated profile or the originar one. Actually, I cannot change this profile.
If PixInsight's Color Management dialog says this, it's because this is the monitor profile currently assigned to your monitor in your Windows. This profile has been generated by (or is part of) the Colorific calibration utility that comes with most Philips monitors.
From the profile signature, it seems that you're working at 9300 K color temperature and gamma=1.0 (linear). Is your monitor a LCD monitor? If it's a CRT monitor (AND the 107B is a CRT), I'd bet these parameters are completely wrong. I don't know of any linear CRT; usually CRTs have gamma=2.2. The 9300 K temperature is also quite incorrect for imaging work except you're doing just plain web production. No printer or proofing device works at such high temp.
If you don't have a reliable calibration device, I recommend you to select the sRGB IEC61966-2.1 standard profile for your monitor. It just works well if you don't have anything better. Also I suggest working at 6500 K (daylight), if your monitor allows you to adjust color temperature (I'm almost sure the 107B does).
To change your monitor profile, right-click on the Windows desktop and select Screen Properties > Configuration > Advanced Options > Color Management. If you remove all profiles here, Windows will use the default sRGB color space for your monitor and all will be fine. Or try running Colorific again if you like the hard way...
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
