Author Topic: Image Solver?  (Read 2588 times)
Offline mads0100
Image Solver?
« on: 2015 August 28 16:54:39 »
Image solver doesn't seem to know how to use XISF files.  Is there a way to make it use them? Active Window mode works fine; it's just the 'files' part of it that doesn't work.
Chris
« Last Edit: 2015 August 28 17:15:45 by mads0100 »
Re: Image Solver?
« Reply #1 on: 2015 August 28 17:42:35 »
Chris
If your using Windows you can type *.* into the filename box and then return. A listing of all files will now fill the selection box. You do need to be using native file handling. If you notice there is a WCS file in that directory. I tested Imagesolver and it did save the resulting file as a xisf.  The *.* works in any Windows program!
