Author Topic: Bottom tool bar hides below screen when using any tool in it. PI 1.08.04.117  (Read 2784 times)
Offline nunopc
Bottom tool bar hides below screen bottom when I use any tool in it. For instance, if I change worspace using the corresponding icon in the tool bar the tool bar disappears. To recover the tool bar I must re-maximize the OS window.
Laptop Toshiba satellite L755 1DR
OS Windows 7 Home Premium 64 bit
Pixinsight 1.08.04.1171 Ripley (x64)
Screen resolution (maximum) 1366 x 768
Nuno
Simply close one or two explorer windows; for example Object Explorer and, if necessary, Script Editor. Or you can move them to the right side of the main window. The problem is that with such a low resolution the selector tabs don't fit in the available vertical space.
Offline tommy_nawratil
hi,
I have the same behaviour - info toolbar hiding - with 1920X1080  res. Need to re-maximize window to bring it up again.
Even there are no explorer windows open. What is the minimum res to avoid?
Tommy
Offline nunopc
Hi Juan,
I did as you recommended: closed 2 explorer windows and it solved the problem.
I'm still learning to use Pixinsight and enjoying it in every aspect. It's a great platform not only in functionality but also UI - very consistent and well designed in terms of usability.
Thank you!
Nuno
oh, I got the message - not "explorer windows" but "selector tabs" - thanks for helping out my weak brain  ::)
Tommy
