Author Topic: Max number of subs for image integration?  (Read 2760 times)
Offline andyc67
« on: 2015 August 14 10:28:09 »
Is there a max number of frames for image integration?
If so what is it?
Thanks!
Andy
Offline chrisvdberge
Re: Max number of subs for image integration?
« Reply #1 on: 2015 August 14 10:53:39 »
I would think not. The only thing you will run into is the limitations of your computer ;)
I've been stacking 200+ images in one integration run for instance, but that took something like 6 hours to complete
« Reply #2 on: 2015 August 14 11:55:35 »
It depends on the Operating System.
Se here for an explanation, workarounds, etc:
http://pixinsight.com/forum/index.php?topic=6881.msg55916#msg55916
« Reply #3 on: 2015 August 15 01:51:33 »
The ImageIntegration tool has no specific limit. The only practical limit is the maximum number of simultaneous open files allowed by the operating system:
Linux and FreeBSD: The default limit is 1024 files, but it can be increased very easily with the ulimit command. Non-privileged users typically can increase the limit up to 2048 files. With root privileges the limit can be set to any number with ulimit.
Windows: The maximum number of open files is 2048. This limit cannot be increased, and most likely Windows will impose a lower limit under the hood.
OS X: The default limit is 256 open files. The ulimit command does not work. Recently a user has found a solution on OS X 10.10 that involves creating a system daemon script.
Offline andyc67
« Reply #4 on: 2015 August 19 13:02:23 »
Thanks! I use OS X that explains it.
I will try the workaround. I have been stacking the files in batches then stacked the resulting partial stacks.
Thanks for the great info!
Andy
