Author Topic: L RGB  (Read 3831 times)
Offline Harry page
L RGB
« on: 2008 October 10 14:15:00 »
HI All
I want to combine some Luminance taken with a sxv H16 and Colour taken with a sxv m25 single shot
colour camera!
Could anyone give e some big hints, direction as I am really finding this difficult
Regards Harry
Harry Page
Offline twade
L RGB
« Reply #1 on: 2008 October 11 13:01:51 »
Harry,
Juan's tutorial on LRGB is where I got started.  Using Previews is essential as it allows you to fine tune its inclusion into the RGB image.  I generally find either bright or dark nebula in the image and create a preview and clone it several times. In ReadOutOptions under the Global section of the Process Explorer, I set "Probe size in pixels" to 9x9 or 15x15.  I then mouse over a reasonable section in an unaltered preview and write down the pixel location of the cursor and the associated RGB values.  With ONLY the L channel selected in the LRGBCombination dialog drag the process icon over one of the previews.  I then mouse over the same location in the altered Preview and compare the values.  While tweaking the Luminance slider in the Transfer Functions section, I iterate through this process until the unaltered RGB values are similar to the LRGB.  Once completed, I then tweak the Saturation values to taste.
Here's Juan's tutorial:
http://pixinsight.com/tutorials/STD/LRGB/en.html
I hope this helps,
Wade
Offline Harry page
L RGB
« Reply #2 on: 2008 October 12 01:18:44 »
Hi wade
Thanks for the tip , will have a go and see how bad I can get
Regards Harry
Harry Page
