Author Topic: Processing Tutorial: LRGB Techniques in PixInsight Standard  (Read 26219 times)
Offline Pleiades
  • Administrator
A new processing tutorial is now available:
LRGB Combination Techniques in PixInsight Standard, with Jim Misti's M63 CCD Image, by Juan Conejero (PTeam):
http://pleiades-astrophoto.com/tutorials/STD/LRGB/en.html
This tutorial explains the principles and practical usage of the new LRGBCombination process, through a complete, worked processing example.
LRGBCombination is intended to change the way you produce your color CCD images. It is an advanced, rigorous implementation that solves the problems that have been traditionally associated with this essential technique: no more hue changes, desaturated images, or noise transferences between luminance and chrominance.
Special thanks to Jim Misti for giving us permission to use his excellent M63 raw data to write this tutorial.
Hope you'll like it.
The Pleiades Development Team
Offline jramper
Re: Processing Tutorial: LRGB Techniques in PixInsight Standard
« Reply #1 on: 2015 June 21 12:06:13 »
Hello, I´m a begginer of LRGB images integration. Could you help about?
I was trying this Url :http://pleiades-astrophoto.com/tutorials/STD/LRGB/en.html
but it doesnt work properly, gives an error.
Thanks for your help :D
« Reply #2 on: 2015 June 21 13:15:00 »
Hi jramper, welcome to the forum. Some videos were replaced by new ones.
You can see this video or this video that will help about LRGB Combination.
Hope this helps.
Saludos, Alejandro.
