Author Topic: not able to select mask  (Read 3159 times)
Offline alcol
« on: 2015 July 11 06:54:29 »
I am v new to PI, just started to use the trial version.
Selecting a mask did work, but I can't get it to work now. I have opened the luminance channel of an RGB image using channel extraction and the gone to Mask to Select Mask. It opens the process window but when I click on New Mask, the only option is No Compatible Images. I have turned PI off and on again but still no joy. Probably something simple I am doing wrong!!
Look forward to hearing from you
Offline avastro
Re: not able to select mask
« Reply #1 on: 2015 July 11 08:04:27 »
This is one of the place where you'll find a lot of answer.
http://pixinsight.com.ar/en/docs/tag/1/mask.html
Cheers
Antoine
Antoine
Lentin Observatory
Offline Cosmick
« Reply #2 on: 2015 July 11 21:19:30 »
Make sure you have the original image highlighted before trying to select the mask. You can also drag the identifier tab from the luminance and drop it onto the original, just under its identifier tab.
http://www.pixinsight.com.ar/en/docs/1/pixinsight-apply-mask.html
« Last Edit: 2015 July 11 21:37:55 by Cosmick »
Clear Skies
Mick
