Author Topic: Can I make an artificial flat in PI?  (Read 4320 times)
Offline astrovienna
« on: 2015 June 30 20:22:10 »
I have some dust donuts (yeah, I forgot to take flats a couple nights . . . )  I take care of this in PS by making an artificial flat:  clone out the stars, crop the galaxy and paint it in with the surrounding areas, blur it a bit, then subtract that flat from the original with an offset value.  Is there a way to do this in PI?  Something with PixelMath?
Kevin
Offline TobiasLindemann
    • Trackingstation
Re: Can I make an artificial flat in PI?
« Reply #1 on: 2015 June 30 21:40:17 »
Hi Kevin,
Dave has posted this for a couple of weeks:
http://trappedphotons.com/blog/?p=756
I have not tested it yet, but it looks good.
Greetings
Tobias
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2015 July 01 10:40:57 »
Hi Kevin!
The quick and dirty way WITHOUT PAINTING(!) by using the data itself is:
Take your RAW Image from the mono camera (or debayered RAW from the OSC)
1. Prozess ABE or DBE  - this creates a longwave background model without any stars very similar to a real flat field. (Downsampling Factor to 1.0 instead of 2.0)
2. USE PixelMath      $T / backgroundmodel
These 2 steps are the basic idea, you can expand it with your own ideas to increase quality.
Gerald
P.S.: Thanks to Rob (pfile) you can reduce the steps. i did it already in this message...  (I have not seen until today the Downsampling factor for the Background)
        Thank you Rob for pointing me to that!
« Last Edit: 2015 July 01 12:44:52 by oldwexi »
« Reply #3 on: 2015 July 01 10:45:35 »
also you should be able to tell ABE (or DBE) to produce a full size background model by changing "Downsampling Factor" to 1.00 under the Interpolation and Output tab of the ABE process window.
the problem with the ABE/DBE method is that it's not going to correct dust donuts. but depending on the f/ratio of your system, you may not see any dust donuts in your images.
Offline astrovienna
« Reply #4 on: 2015 July 02 08:22:01 »
Thanks for the help, folks.  I'll try that next time.
Offline dnault42
« Reply #5 on: 2015 July 02 10:39:05 »
I did the synthetic flat tutorial for those cases where ABE & DBE are not able to fully correct the field due to the structure sizes involved (too small) and as Gerald says it requires painting (i.e. CloneStamp) and sometimes a lot of it.  ABE and/or DBE are the better and faster solutions for most issues, but if you find they aren't able to correct your image you may venture into the synthetic flat territory.
David
