Author Topic: Combining Ha to RGB  (Read 3827 times)
Offline joelshort
    • Buckeyestargazer.net
Combining Ha to RGB
« on: 2015 May 14 13:50:11 »
I'm sure this has come up a million times but I'm not seeing the info I'm looking for.
I'm exploring ways to combine Ha with R (and GB) for an HaRGB image.  I'm trying to understand this tutorial by Vicent:
http://pixinsight.com/tutorials/narrowband/
First, Vicent hints that this process will be automated:  "Since the algorithm can be easily automated, it will be implemented as a PixInsight module as soon as possible."  Has this happened yet?
Second, it's not clear to me whether this continuum map algorithm as described is done in the linear or non-linear stage.  Could someone clarify?
Joel Short
www.buckeyestargazer.net
Offline topboxman
    • Peter's Gallery
Re: Combining Ha to RGB
« Reply #1 on: 2015 May 14 14:22:12 »
I am at work so I don't remember the exact name of the script that's already in latest PI. There are two of them and I like one better than the other.
I found the PI forum thread about the original author of the script:
http://pixinsight.com/forum/index.php?topic=3446.0
It's a long thread but the script I am talking about is based on the original author plus it does a little bit more.
Peter
Offline joelshort
« Reply #2 on: 2015 May 14 14:46:47 »
Peter, is it NBRGBCombination script?
Joel Short
Offline topboxman
    • Peter's Gallery
« Reply #3 on: 2015 May 14 15:11:38 »
Yes!!!!!
Use the link I provided as a guide to learn how to use the script. It's pretty easy.
Peter
Offline joelshort
« Reply #4 on: 2015 May 14 15:16:54 »
Sometimes I just don't see things that are right in front of me.  I should have seen that script the first time around when I looked before asking on the forum.
That is exactly what I needed.  I believe that it is based on Vicent's method in the link above.
Joel Short
Offline topboxman
    • Peter's Gallery
« Reply #5 on: 2015 May 14 15:25:07 »
Yes it is based on Vicent's method. Harry also created a video tutorial based on Vincent's method and the script is based on Harry's tutorial.
I think it would be educational to watch Harry's video tutorial because it shows the inner workings of the script.
http://www.harrysastroshed.com/pixinsight/pixinsight%20video%20html/pixinsighthomeinter.html
Look for "Adding Ha to RGB".
Peter
