Author Topic: Image Calibration Failure  (Read 2603 times)
Offline Bennie
« on: 2015 May 11 02:06:37 »
Hi All
I am trying to combine images taken with two different telescopes and cameras ,when calibrating the light frames from my Canon 1100d I get the error as per attached TEXT doc & jpg. Same camera used for all the canon exposures.
I calibrated the lights from my Nikon with no problem even after converting master dark,bias,flat from tiff (DSS) to fit for calibrating the lights.
Any help appreciated
Thank you
Offline Bennie
Re: Image Calibration Failure
« Reply #1 on: 2015 May 11 05:49:50 »
Found problem the calibration process can not distinguish between images with different rotation.
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« Reply #2 on: 2015 May 11 12:18:03 »
Hi Bennie,
Here's the problem:
Reading FITS: 32-bit floating point, 3 channel(s), 4290x2856 pixels: done
Reading FITS: 32-bit floating point, 3 channel(s), 2856x4290 pixels: done
You are using calibration frames and light frames with different sizes.
Tip: use BBP script, from the beginning. Maintain all preprocessing inside PI, and enjoy :D
Greetings!
Enzo.
Offline Bennie
« Reply #3 on: 2015 May 12 01:50:22 »
Thank you Enzo
I shall use the script in future , very much new to PI.
After I turned all the frames to match the orientation of the lights the calibration was successful.
I have old data that I shall now reprocess entirely in PI.
Thanks for the help.
Bennie
