Author Topic: After double clicking a process in the explorer please re-dock the explorer  (Read 17405 times)
Hi Juan,
another itty bitty thing that I think would make PI a little easier to use. I end up using the process explorer more than the process menu to select my processes. After double clicking a process the explorer stays in place, obscuring my image. Should it disappear (re-dock) after a process has been started? Or is the intent that it stays open so more than one can be started?
Thanks!
This is an interesting point. After considering the pros and cons of hiding the Process Explorer window automatically when a process has been launched, I decided not to do that.
You can hide the Process Explorer (as any auto-hide window) by simply hitting the Esc key, or by clicking on its associated vertical tab. Both methods are very easy and fast, so I decided to keep the window open because this facilitates launching several interfaces, as you've pointed out.
Anyway, nothing stops us from adding this as an option to preferences (Hide the Process Explorer after launching a processing interface). What do you think?
Offline David Serrano
Quote from: "Juan Conejero"
Preferences for everything ;). Maybe in some sort of "Advanced" section, so as to keep the interface uncluttered.
 David Serrano
