www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
Image processing Halfa
« previous
next »
Print
Pages: [
1
Author
Topic: Image processing Halfa (Read 4682 times)
gianpri
Member
on:
2015 March 01 13:01:41 »
How to process images Halfa? It should first be calibrated as thought they were all RGB images and then process only the red channel ? Or is it best to first extract the red channel and then calibrate and process only this? Thank
Giovanni
Logged
Zocky
PixInsight Old Hand
Re: Image processing Halfa
Reply #1 on:
2015 March 01 14:13:32 »
First you should calibrate and integrate like any other channel. Then you need to combine H-alfa with LRGB. You can do that by using a pixel math or by using a script.
Logged
gianpri
Member
Reply #2 on:
2015 March 02 03:55:53 »
Thanks Zocky, but I want to get just a gray picture, no color. Why should I combine H-alpha with LRGB ?
Giovanni
Logged
NGC7789
PixInsight Old Hand
Reply #3 on:
2015 March 02 05:28:04 »
It sounds like you may be shooting with a DSLR or other color imager. Is that true? Zocky was assuming you wanted to add Ha data to a normal RGB image. If you are shooting with a DSLR you may want to review this thread:
http://pixinsight.com/forum/index.php?topic=5748.0
Your challenge will be what to do with the "wasted" pixels in the G and B channels.
-Josh
Logged
gianpri
Member
Reply #4 on:
2015 March 02 08:18:40 »
Thanks, Josh. The problem is with the flat field calibration of images Halfa. What I've shown is just what I wanted. I hope.
Giovanni
Logged
NGC7789
PixInsight Old Hand
Reply #5 on:
2015 March 02 08:54:03 »
If you have shown anything I cannot see it. Did you include an image?
Please clarify your camera?
As you are talking about extracting channels I will continue to assume you are using a DSLR or other one shot color. In such a case as I understand it you must calibrate before extracting channels as extracting channels imply debayering. It's too late to calibrate after debayering.
Once you have calibrating there are various ways to get Ha data out of a DSLR or one shot color but in all cases you have to give up resolution (there are only so many red pixels) and avoid contributions of noise from the G and B pixels.
-Josh
Logged
Zocky
PixInsight Old Hand
Reply #6 on:
2015 March 02 13:46:24 »
Giovanni, like Josh has suggested, please give us some info on your imaging equipment. Than it will be much easier to discuss.
Logged
gianpri
Member
Reply #7 on:
2015 March 02 15:58:42 »
Forgive my English. I photographed IC 434 with 350D DSLR with filter Astronomic 12nm.Telescopio SW ED80. 14 subframe 480". I had problem to calibrate the lights. Now, following the thread reported by Josh I achieved a good result.
Giovanni
Logged
Zocky
PixInsight Old Hand
Reply #8 on:
2015 March 03 14:08:50 »
Is your EOS 350D modified? If not, I would recommend modification, for better H-alfa images.
Logged
gianpri
Member
Reply #9 on:
2015 March 03 15:17:46 »
Yes, my Canon 350D has been modified with Baader filter. Otherwise you'll be completely blind in Halfa.
giovanni
Logged
Warhen
PTeam Member
PixInsight Old Hand
Reply #10 on:
2015 March 10 06:23:54 »
alpha, rather than alfa. Ha = H-alpha. :>)
Logged
Best always, Warren
Warren A. Keller
www.ip4ap.com
Print
Pages: [
1
« previous
next »
PixInsight
General
