Author Topic: Dark & Flat Frame - Need Help  (Read 2493 times)
Offline ketut
« on: 2015 February 20 22:44:42 »
Hi guys,
Should we always take flat more than dark frame or vice versa?
Any rule about this?
Thank you
Ketut
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Dark & Flat Frame - Need Help
« Reply #1 on: 2015 February 21 06:17:10 »
Ketut,
If you are asking about how many subframes, Just because of time factors, you almost always take more dark and bias frames to build your masters than your flat frames.  For example, because I can do the darks and bias at home, I shoot 100 dark subs and 400 bias subs to build my masters.  For flats, since they are taken in the filed, I take 25 or 36, depending on how much time i have available.
If you are asking about how long the frames should be time wise, your darks should be at least as long as your light frames, and if you are doing scaling, some argue they should be up to 5 times as long.  Flats, on the other hand, are much shorter, typically under 10 seconds, just long enough to get to around 32,000 counts in the brightest section of the flat frame.
Hope that helps.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline ketut
« Reply #2 on: 2015 February 24 23:43:34 »
Thank you, Jim!
