Ron,
I used to have this problem all the time and came up with a number of solutions that I have discussed re this and other FITS compatibility issues a number of times here, particularly between MaximDL and PI. There is any easy fix for the problem you are experiencing. Just go into MaximDL and do a batch convert of the files from 16Bit to 32bit floating point. That should solve this particular problem, but if you still have issues in ImageCalibration, insert the following in the "Input Hints" section: lower-range 0 upper-range 65535
That should take care of the black holes. If you are having any other weird effects, such as images appearing blown out, just let me know and I will copy here my entire fix note from an earlier set of posts.
Jim
