Author Topic: Message Error in DBE  (Read 4380 times)
Offline C. Sonnenstein
« on: 2008 August 27 09:13:13 »
There is a error message in DBE instance says that less than three background samples have been defined. Obviously, I have defined more samples in this case.
I report a screenshot with the workflow:
What happens?
Carlos Sonnenstein
« Reply #1 on: 2008 August 27 09:35:37 »
Well, it seems this error message only happens with this image. I have tried with others different formats and sample files, and DBE it works fine.
Carlos Sonnenstein
« Reply #2 on: 2008 August 27 12:34:16 »
Hi Carlos,
This isn't a bug. It happens because despite the fact that you've defined more than three samples, less than three of them are significant. A significant DBE sample has statistical weights greater than zero for the three channels (in a RGB color image). Watch the Wr, Wg and Wb values.
The best way to ensure that more samples are significant, is to increase the Tolerance parameter and/or Shadows Relaxation.
Let me know if this is what happens in your case.
« Reply #3 on: 2008 August 27 13:46:20 »
Juan you are right, it is not necessary at all to increase the tolerance and/or shadows relaxation parameters, only I put some more samples in the upper of the image and then the algorithm runs.
Thank you.
Carlos Sonnenstein
