Hi Guys,
I'm a bit confused as to what I'm doing wrong, but I've been having a few issues with StarAlignment & GraidentMergeMosaic. I've done this before with success, but I didn't do it the way the tutorial shows.
My main issue is the message "Error: Current image width differs from first image width." I'm pretty sure I'm messing up the star alignment, but I cannot get StarAlignment to work the way the video tutorial is showing.
I did generate a master mosaic with seams using Star Alignment. But, the Register/Match only processes one frame and then stops. It's not working for me like in the video tutorial.
When I use Star Alignment, am I supposed to use Register/Match or Register/Union Separate? I always thought it was register Union Separate.
If I use Register/Union Separate, and add one frame at a time, which registration image should I be using? Is that what's causing the Image Width Error? Using the wrong registration image?
If I select Register/Match Images and select my 4-panels, it seems to output the original registration image.
