Author Topic: batch processing warning message  (Read 3079 times)
Offline whwang
« on: 2015 January 25 16:09:30 »
I got a warning message: "No correlation between the master dark and target frames (channel 0)"
Does any one know what the message means?  Should I worry about it?
Wei-Hao
Offline Geoff
Re: batch processing warning message
« Reply #1 on: 2015 January 25 17:59:39 »
Do a search on "no correlation". You'll be inundated with hits.
Geoff
Don't panic! (Douglas Adams)
Offline whwang
« Reply #2 on: 2015 January 25 20:05:28 »
Thanks, Geoff.
Looks like it implies that no dark subtraction will be done in the calibration, which seems quite odd to me.  My camera is Nikon D800 (hacked to restore its true dark level), which is known to have low dark current.  The environment is cool (2-8 deg C) and the camera is not actively cooled.  I can believe that the dark has very small contribution to the pixel values, but should not be zero.  Because my darks are taken under controlled conditions that are very close to the condition of the light frames, I would say that the required scaling factor should be very close to 1.0.  On the other hand, after doing the search you mentioned, I saw that Juan thinks we should trust the judgement of dark optimization.  According to the dark optimization, 0 is the right scaling factor.  This is very puzzling.
Any insight on this?
Wei-Hao
« Last Edit: 2015 January 25 20:10:51 by whwang »
Offline Don
« Reply #3 on: 2015 January 26 17:19:27 »
Hi Wei-Hao,
It looks like it's a flat that generated the "no correlation" message.  That's not so unusual with sub 1 second flats.  When I don't see that message in flat calibration, the correlation factor is always very low.
Don
Offline whwang
« Reply #4 on: 2015 January 27 11:57:56 »
Hi Don,
Thanks!!  I did not realize it is for flat.  I just paid attention to the warning message but not anything else.  It now totally makes sense.
Wei-Hao
