Author Topic: Simplest way to boost saturation  (Read 5968 times)
Offline M Covington
« on: 2015 January 19 08:05:52 »
What is the simplest way to boost color saturation all over a picture, for all hues?  I'm looking for something analogous to +20 saturation in Photoshop or +20% saturation in DeepSkyStacker.  The specific need is DeepSkyStacker autosave.tif files, which have unusually low color saturation and always require boosting.  Thanks!
Offline cdesselles
Re: Simplest way to boost saturation
« Reply #1 on: 2015 January 19 09:34:32 »
Use Curves Transformation tool. Select the "S" icon for saturation.  Drag the curve up. That simple.
« Reply #2 on: 2015 January 19 09:56:50 »
Or the ColorSaturation tool, if necessary with Range increased.
Offline bitli
« Reply #3 on: 2015 January 19 12:39:43 »
Somewhat contrieved, but you could also extract the L and apply the original image to the L via LRGB channel combination, strongly increasing the saturation (and possibly cleaning some color noise in the same pass).
-- bitli
Offline M Covington
« Reply #4 on: 2015 January 19 17:31:02 »
Thanks.  Georg: Increasing the Range to about 6 was the key to it.
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
« Reply #5 on: 2015 January 20 11:27:07 »
Bitli,
Can you expand on your tip.  I always thought that doing the LRGB channel combination reduced saturation, at least when first combining an RGB with a Lum.  If that is correct (and it might not be), what changes with the second iteration?
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
« Reply #6 on: 2015 January 20 14:08:26 »
Jim,
What Bitli is doing is using the LRGBCombination tools Saturation Transfer function to increase color with the extract L image. The nice thing about this method is the tool has color noise reduction built in if you need it or want to use it.
Offline jkmorse
« Reply #7 on: 2015 January 20 14:53:46 »
Mike,
Thanks, that makes perfect sense.
Jim
Apogee Aspen 16803
Offline cdesselles
« Reply #8 on: 2015 January 20 14:57:22 »
This LRGB Combination method intrigues me.  I've not attempted that process yet.  Could one of you please give a more complete "step by step" of what you are doing here (and why).
« Reply #9 on: 2015 January 20 15:59:30 »
All that is happening is we extract the CIE L* component image from the original RGB image. Use that L image with the LRGBCombination tool. Set the desired color saturation level. Here is the part that I think throws people off, less is more saturation. As we adjust the saturation parameter towards 0 we are increasing the saturation level. It's the math behind the tool I would guess. Then nothing more then applying the tool to our image. Your not creating a new image just acting on the original. The great thing about this method is the built in noise reduction.
Here is a posting about this aspect of the tool. The entire post is good reading.
http://pixinsight.com/forum/index.php?topic=2485.msg16706#msg16706
Offline Warhen
    • Billions and Billions
« Reply #10 on: 2015 January 27 08:08:30 »
Jim, as Mike says- adding Sat with LRGBC is convenient, and CNR is offered, but while I began this way, I'd strongly recommend avoiding it Adding Sat globally/unmasked increases chrominance noise in the BG and dim areas, which the CNR can't fully make up for. Better to add Sat independently using an L or Range mask.
Best always, Warren
Warren A. Keller
www.ip4ap.com
« Reply #11 on: 2015 January 27 14:38:03 »
Warren,
I totally agree with using a mask. You can mask your image while increasing the saturation using the LRGB Combination tool in the same way you would with the Color Saturation tool or Curves.
