Author Topic: New Version 1.6.1 of the PixInsight Documentation Compiler Script  (Read 8113 times)
For developers --- I have just released version 1.6.1 of the documentation compiler script for all platforms. This version comes with lots of new features and improvements; among them:
* Automatic section numbering and symbolic referencing of sections, tables, figures, equations and bibliographic references.
* LaTeX equations and math fragments can be embedded in PIDoc source files. This is easier than ever with the new verbatim blocks feature.
* Improved automatic generation of interactive resources, such as mouseover image lists.
* Automatic syntax highlighting of source code blocks in the JavaScript, C++, XML, PixelMath and PIDoc languages.
* Collapsible sections for easier navigation of large documents.
* Unlimited nested subsections.
* New PIJSObjectDoc document class for documentation of JavaScript objects.
* The compiler generates fully standards compliant HTML5 / CSS3 documents that pass W3C validators with zero errors and warnings.
* Large documentation projects can now be structured as multiple .pidoc files thanks to the new \include command.
* New \pragma command to control most compiler features from PIDoc source code.
* The target documentation system is now remembered across script executions.
The documentation for the PIDoc markup language has also been updated to reflect the latest version:
http://pixinsight.com/doc/docs/PIDocReference/PIDocReference.html
Hope you'll like it!
Offline bitli
Re: New Version 1.6.1 of the PixInsight Documentation Compiler Script
« Reply #1 on: 2015 January 19 05:59:41 »
Thanks, I will look at it soon.
Can the end user install a new doc (from example the doc of a script or process provided on GitHub) without requiring administrative rights ?
-- bitli
Offline mschuster
« Reply #2 on: 2015 January 21 10:08:52 »
Hi Juan,
Thanks for the new features. I am using some of them now, they are working well. PIDoc really is a nice documentation environment, thank you for making it available.
Would a "Compile & Run PIDoc Document" command to the Script Editor be possible? It would open a browser window on the compiled document.
« Reply #3 on: 2015 January 21 12:46:11 »
Hi Mike,
Thanks!
Definitely yes, I am missing this feature too, especially these days since I'm working a lot on complex documents (XISF). I'll try to implement this in the next version.
« Reply #4 on: 2015 January 21 12:50:49 »
-- bitli
This can only be done through an update. You can create your own update repository, or you can send the documentation (PIDoc source) to me and I can release an update for you.
A "Process > Feature Documentation" main menu option has been suggested before. I'm thinking on the best way to implement it. Perhaps in the next version.
Offline mschuster
« Reply #5 on: 2015 January 22 19:13:03 »
Hi Juan,
I can't find a table of \figure parameters in the document. Maybe it got dropped?
« Reply #6 on: 2015 January 24 02:38:28 »
Hi Mike,
Yes, the \figure command only takes block parameters. I have tried to be very careful to avoid incompatibilities with previous versions. Do you have problems with this command in version 1.6.1?
Offline mschuster
« Reply #7 on: 2015 January 24 19:04:16 »
Hi Juan,
\figure accepts numbered and unnumbered like \table, both very useful. Both listed as \table parameters but not for \figure. Should they be?
Mike'
« Last Edit: 2015 January 24 20:05:24 by mschuster »
Offline mschuster
« Reply #8 on: 2015 January 24 23:04:33 »
Hi Juan,
A minor issue:
\image a/f.png
\image b/f.png
seem to result in a f.png name conflict and overwrite in the compiled images/ directory. A unique naming feature would be nice to have.
Offline mschuster
« Reply #9 on: 2015 January 25 08:46:17 »
Hi Juan,
You posted a html link to your 2nd xsif document in a post. I would like to do the same for my compiled document, however it contains local file system refs to style and images, which are not rendered when I open a copy of the html saved in a different location. I assume you encapsulated everything into single file to make this work. How did you do that?
