First, since this is my first post here (hi!) I thought I should include a brief introduction:
I have been imaging for about 12 years, starting with a DSLR attached to a 6" Newtonian, and iterating my setup many times. Currently I have two main scopes, a Tak FSQ-106 and a Celestron Edge-HD 11, plus a QSI583wsg, mounted on an Astro-Physics Mach1. In the past, I've used numerous image processing and capture software systems, previously ImagesPlus (now a long time ago with the DSLR) and for the past several years Maxim DL. I'm still intending to use Maxim for capture and control, but I've recently started using PixInsight with the hopes of getting finer control over the process and some extra processing features.
I'm just getting started reprocessing some data from last summer, running the latest rev of PixInsight on a desktop machine I built for the purpose (with a Core i7-4790 & 8GB of RAM).
Anyway - first of many questions:
I've read (and watched) many tutorials, but wanted to check that what I'm doing with calibration is sensible; I'm doing something a little different to any of the tutorials that I've seen.
What I typically do is take flat-darks, ie a set of darks with the same exposure time as my flats (2 seconds in this case).
I start by building master bias frames by just integrating a set of 50 bias frames, and then a master flat-dark and a master dark the same way, and integrating each.
Then for each filter:
I then calibrate the flats using the bias and flat-dark. I have the "calibrate" checkboxes for the master bias unchecked, but for master dark (which is the flat-dark) checked, because I didn't previously calibrate the flat-dark frames individually. From that, I build a master flat with integration.
Finally for light calibration I use the bias, master flat and master dark frames, with:
calibration unchecked for master bias
unchecked for master flat
checked for master dark, because no calibration was applied to individual dark frames.
Is this correct? Any comments or suggestions much appreciated...
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
