Author Topic: QHYLIIC debayering  (Read 2335 times)
Offline lómbido
QHYLIIC debayering
« on: 2015 January 07 02:15:24 »
Good morning
I have tried deep sky with QHYLII C. It seems the only working debayer method is super pixels. It leads to half resolution. Is there any other way? I leave a raw capture.
https://www.dropbox.com/s/q1xyt7wdeh0yksl/L_M42_2014-12-21_23-39-44__na.fit?dl=0
Many thanks
Offline oldwexi
    • Astronomy Pages G.W.
Re: QHYLIIC debayering
« Reply #1 on: 2015 January 07 07:44:11 »
If you use "GRBG" as the Debayer pattern, you will get your M42 with correct colors.
As you have a strong red hue in the debayered image, using STF with unlinked RGB channels gets you
nice correct colors in the very noisy image after debayering.
Gerald
Offline lómbido
« Reply #2 on: 2015 January 07 07:55:01 »
Many thanks,
it works.  I thought that pattern did not work but it does.
Regard
