Author Topic: Script MaskedStrech --> After finish the star have problem in the center  (Read 3377 times)
Offline Leandro VARGAS
Hello,
Every time I make the stretch with the script Maskestrech the stars are in the center with higher saturation than the rest of the star, it is like watching a donut, with the script I make a stretch up to 50%, no more, but the start have the same problem for different picture .
You know what is the reason that occurs?
There is another tools to Replace this script Masketestrech?
Thank you,
Leandro
Offline Dimitris Platis
Actually MS is the best way to get good star saturation......so there are several ways to deal with this
1) look at this tutorial (http://www.pixinsight.com.ar/en/info/processing-examples/28/maskedstretch-stars-sores.html)
2) U can use a star mask and apply a convolution algorithm
3) Perform MS only on RGB image and simply Histrogram stretch Luminace so at the LRGB stage you will have less of a problem while maintaining good color
Offline oldwexi
    • Astronomy Pages G.W.
Hi Leandro!
My personal experience with MS is very positiv. I get nice small stars with proper center, except:
when one of the 3 channels is not focussed properly then  I also experience bad star centers.
But i see this as my fault not as a MS fault.
Gerald
Offline gvanhau
Leandro
Did you try using the masked stretch tool (not the masked stretch script) they are slightly different.
Regards
Geert
Geert Vanhauwaert
Offline Warhen
    • Billions and Billions
Just a general thought for all of us, and not directed to Leandro at all! It's good practice to first search the archives before posting  a 'new' question. This is an example of a question which has been discussed several times. The search filter here is good, and adding to an existing thread keeps down bandwidth and makes for easier searching. An exception would be a very old thread which might not be seen. Just my 2 cents. :>) Happy new year all!
Best always, Warren
Warren A. Keller
www.ip4ap.com
Hello,
Thank you very much for the comments, I will experiment with MS tools with my DSLR Nikon D600 camera.
Happy New Year.
Leandro
