Author Topic: update my default process icon  (Read 2383 times)
Offline elbee
« on: 2014 December 27 14:29:37 »
i have a saved set of process icons i load when starting PI.  if i want to change the initial parameters for one (like DBE), how can i do that?
the sledge hammer approach for me is to create a new one with the settings i want, then delete the old one and resave the entire set including the revised one... i would think there is a way to simply update the existing icon.  can that be done?
thanks
Lee (PI newbie)
Re: update my default process icon
« Reply #1 on: 2014 December 27 15:09:23 »
Lee,
Right click on the process icon you want to edit. Select 'Edit Instance Source Code'.  Change the parameter. Click on the Check Mark'Commit' in the upper right corner. Now that you've changed that icon you well need to select all your icons and resave the set.
